22inch Ek
Bigbird
- Contact:
Re: 22inch Ek
PM sent
www.drive1.net.au
www.thedrive1team.blogspot.com
www.facebook.com/pages/Melbourne-Australia/The-Drive-1-Team/401541923693?ref=ts
Re: 22inch Ek
Ummmm, he just did, public forum rememberratbox wrote:you don't tell themwhat they don't know won't hurt them
Even if posts are deleted there are still copies cached somewhere for months afterwards.
Re: 22inch Ek
Nothing will be going into the car that cannot be engineered... If it doesnt pass. We'll put the std hr front back in an order wheels to suit
Re: 22inch Ek
Interesting post about the crossmember.
I have a question, was speaking to Theo (Thropzed i think its spelt) quite a while ago about lowering an EK/FB while retaining the full suspension travel by shortening the mounts on the crossmember that bolt it to the subframe. I was looking at it a while ago and if you made it so that it bolts almost flush onto the crossmember, instead of however (3" roughly perhaps?) tall the mounts are it would lower the car while keeping full suspension travel.
Does anyone know if that is legal / heard of anyone doing that before?
Nick.
Re: 22inch Ek
yes i've done it a number of times, this one had the mounts droped + drop stubbs + cut springs went over a dip in the road and ripped the steering offDeadSled wrote:Interesting post about the crossmember.
Re: 22inch Ek
If you put larger wheels like say 22s on it ,it would be a different story
black duck
Re: 22inch Ek
[/quote]
HEY STARSHINE
you might have weakened the steering when you rolled it off your famous rotisserie.
[/quote]HEY STARSHINE
Re: 22inch Ek
this one never went on the rotissery, did plenty of carefull miles and one day dip bump bang steering wheel ripped out of my hand and not very responsive when i got back hold of it
got it home it had broken the the 2 bolts that hold the idler arm to the subframe
black duck
Re: 22inch Ek
whats that got to do with lowering the crossmember mounts ?
Re: 22inch Ek
quite alot if you've seen under an FB/EK the lower it gets the closer the steering gets to the ground and by lowering the mounts it lifts the crossmember up and the steering components stay in original position thus are far moer exposed to objects on the road or as in my case poor condition of the road
somebody asked if it had been done i answered as i've done it
what do yor stoopid comments have to do with lowering the crossmember mounts
black duck
Re: 22inch Ek
why have you done it a number of times if you knew it was dangerous ?
Re: 22inch Ek
Wouldnt it have snapped from the excess pressure on the idler arm and steering box mounts ( the bolts ) because after you lowered the cross member mounts they were twising in a sliughtly diff direction and adding pressure to the mounting spots?
Probably wouldnt effect non steering box type set ups. But anything with a sterring box it may?.. Without looking at a car or anything, just an assumption.
Re: 22inch Ek
because he realised the dangerouseness and used a rack to counteract the hemispherical volume of the poofel valve during pivot twist
