harvs ek 327 wagon
Re: harvs ek 327 wagon
Got the tailgate sorted so it doesn't drop. The internal mechanism was very sloppy, so I had shimmed it up with washers. Too much tension on the mechanism, and the rod return springs could not cope. Replaced the rod return springs with some heavier ones from Bunnings, and all good.
Sorted out the cargo floor latches (recessed them a bit more and fitted fancy cover plates).
Fixed the firewall heater grommet. Pulled the heater hoses, glued the grommet to the firewall, lubed the hoses then fed them back through. Got glycol everywhere despite my best intentions.
Sorted out why the indicators were not cancelling. The aftermarket Autotechnica steering wheel had plastic "cancelling" pins that were nowhere near deep enough to engage the cancelling springs. Made up a new cancelling pin and fitted. Made me smile... I bought that steering wheel (with an LH Torana hub) from K-Mart many years ago. Not sure anyone stocks LH Torana hubs anymore, let alone K-Mart.
Think I have sorted the speedo too - road test to follow.
Kickn goals mate
greenwagon62
Post by greenwagon62 »
Hi Harv, I am doing an EK wagon with a 307 Chev, and just looking at seat belts. I appreciate all the info you have put on the forum, it really helps. Just wondering if you would know the part numbers of the seatbelts you used. Thanks Ian
thebrotherj
Post by thebrotherj »
hey Harv, good to see you've been chipping away at this one. Any photo updates yet?
cheers, Joe
greenwagon62 wrote: Tue Mar 12, 2019 9:26 am Hi Harv, I am doing an EK wagon with a 307 Chev, and just looking at seat belts. I appreciate all the info you have put on the forum, it really helps. Just wondering if you would know the part numbers of the seatbelts you used. Thanks Ian
The belts that I used are made by HEMCO:
• Inertia lap/sash belt with 600mm adjustable buckles (HEMCO part number 1790001)
• Static lap belts with 600mm adjustable buckles (HEMCO part number 1790002)
• XL 0/0º mount inertia lap/sash belts with 600mm adjustable buckles (HEMCO part number 1600051XLSP)
• 90º L-bracket mounts (HEMCO part number 1765174)
• Cad-plated floor reinforcing plate with captive nut (can't find the part number).
thebrotherj wrote: Wed Mar 13, 2019 10:27 pm hey Harv, good to see you've been chipping away at this one. Any photo updates yet?
cheers, Joe
Progress has been slow, as the kids are breaking the other vehicles faster than I can repair them. Speedo cable broken, filthy miss and rubbing exhaust on the FB, and buggered starter motor solenoid on the VL. Couldn't move the Camira to get the Torana out so I can get to the Commodore as the Cortina and Camira were in the way.
Managed to get the auto trans cooler plumbed up, and reoriented the handbrake cable brackets to move the handbrake away from the new (quieter) mufflers.
Pulled the shiny new carb down to see why it is idling so rich. Mixture screws were OK (1.5 turns out), and power valve was OK (6.5"Hg valve, car idles at 13"Hg so power valve will be shut). Transition slot appears to be appropriately covered at idle. Suspect main metering jets are a wee-tad large.
Still got to calibrate the speedo - test run and new gear set next time I am home. Should be ready then for the engineer.
Car needs a good wash and tidy up - lots of smeary finger prints don't make it too photogenic. Washer bottle has decided it wants to dribble out the washer jet when the car is sitting around, despite the plumbing being all uphill . Jet is mounted EK-style in the bonnet, so water trails down the bonnet. Will fit a late-model non-return valve and see if that helps.
greenwagon62
Thanks for the info Harv. I'll put some pics of mine on the forum when I work out how to, for some reason it doesn't accept my photos.
greenwagon62
Hi Harv,
With the location of the sash guide where I think it needs to go on the rear pillar in accordance with the code, and then having the retractor horizontal on top of the wheelarch, it appears that my seatbelt will be pulling at an angle over the rear seat top bracket. Just wondering if you found that?
Also have tried attaching a picture of my car below to see if I can get it to work, I have reduced the size of my pictures, which I think has been the trouble so far.
EK JAY
Post by EK JAY »
Hey green wagon I used Harvs seatbelt guide too and yep seat belt runs over the top of the seat brackett
on my wagon I fitted a small piece of tube onto the top of the brackett so the belt ran smoothly over the top as per my engineers suggestion I can send you some pics if I can get it to work I'm having trouble posting pics aswel
(Thanks again Harv :clap: )
EK JAY SINCE 1990
greenwagon62
Thanks Jay, yes that sounds like a good idea to solve the problem, did you just weld a piece of metal tube on? and yes the information Harv has shared has been extremely helpful with my build so far, thanks again Harv.
The main drama with trying to comply with the NCOP code (and hence ADR) for seatbelts is that it is a very "measurement heavy" process. Depending on how far apart you put the side belts on the floor (the "bumcrack line" from the Guide), the sash guide location varies a lot. This is why I send people the Guide, rather than just a distance up the B or C pillar.
When I did mine, I ended up with the rear belts running under the seat bracket.
rear belts 1.JPG (591.8 KiB) Viewed 797 times
rear belts 2.JPG (633.92 KiB) Viewed 797 times
greenwagon62
Harv wrote: Sun Mar 24, 2019 8:49 am The main drama with trying to comply with the NCOP code (and hence ADR) for seatbelts is that it is a very "measurement heavy" process. Depending on how far apart you put the side belts on the floor (the "bumcrack line" from the Guide), the sash guide location varies a lot. This is why I send people the Guide, rather than just a distance up the B or C pillar.
Thanks for the pictures Harv, yes it definately gives me a headache trying to comply with all the measuements in the code. I would love a copy of your guide, if you dont mind. I'll send you a message.
Some photos below. They are not overly artistic, the car is filthy, and in bad need of detailing. They give you some idea though.
Cargo area:
Optimized-Cargo area.JPG (807.83 KiB) Viewed 748 times
... and this time with the tailgate shut after fixing the latch springs:
Optimized-Rear quarter.JPG (647.87 KiB) Viewed 748 times
Fancy Dzus fasteners I used to hold down the rear cargo floor (and the circular cover plates I had to add after finding out that that the carpet depth made them no longer work the easy way):
Optimized-Cargo floor Dzus fasteners.JPG (1.03 MiB) Viewed 748 times
The results of my incontinent windscreen washers:
Optimized-Incontinent windscreen washer.JPG (576.74 KiB) Viewed 748 times
The fancy check valve I added to stop the dribbling (fingers crossed):
Optimized-Check valve in windscreen washer.JPG (520.95 KiB) Viewed 748 times
View from the pilots seat:
Optimized-Drivers view.JPG (646.79 KiB) Viewed 748 times
Loud, hot, noisy thing:
Optimized-Engine bay.JPG (769.71 KiB) Viewed 748 times
The vacuum tank and electric pump I had to add because the cam overlap left no vacuum to drive the brakes. The transmission cooler hose at the bottom of the photos is the one that decided to fall off during the last highway test run:
Optimized-Vacuum tank and pump.JPG (612.77 KiB) Viewed 748 times
Rear seat:
Optimized-Rear seat.JPG (540.66 KiB) Viewed 747 times
Weathershield, with the crappy metal fasteners replaced by nylon bolts:
Steering wheel with dodgy cancelling pins (too short to reach into honeypot and grab the cancelling springs):
Optimized-Short cancelling pins.JPG (709.62 KiB) Viewed 745 times
Home-made cancelling pin:
Optimized-Replacement cancelling spring.JPG (611.07 KiB) Viewed 745 times
Cancelling pin installed in lieu of one of the mounting bolts:
Optimized-New cancelling spring in wheel.JPG (716.9 KiB) Viewed 745 times
Replacement tailgate spring from Bunnings (above, after shortening) with original spring below:
Optimized-Tailgate springs.JPG (753.13 KiB) Viewed 745 times
Engine bay looks fantastic Harv. As do the seats. You got them retrimmed with the silver hounds tooth from SMS Fabrics USA? The icing on the cake that gear mate.
