Hi Clay, sorry it has interrupted your surfing break but better to be safe hey just shows how quick things can change with this COVID thingy.
Stay safe South Australia crew. :thumbsup: :thumbsup:
Thanks and dead right cobber. We were very lucky.Image
Dodgy bonnet corner not too badImage
Leaky axle seal made a mess. Minor dilemma in case I go EJ brakes. Can't get parts right now anyhow.ImageImageImageImage
Other side had a slight gum which smelt of diff oil. Fronts just dust. Passenger front quite a bit.Image
The water looks fantastic.
Errol62 wrote: Thu Nov 19, 2020 12:17 pmLeaky axle seal made a mess.
That's just NASCO rustproofing. Works in tandem with the sump oil from the walking stick, the gear oil from the gearbox selectors and any grease thrown by the uni grease nipples.
Adjusted the brakes. The pedal came right up and now firm. Bleeding deemed unnecessary now master cylinder is operating in its correct range.
Reset front toe to 3/16".
uuurrrgggghhhh ,that looks yuk ....... shack looks nice though , where is it ??? I could move to SA tomorrow , the bride is not too big on ever moving again though sadly ...... :(
Blacky I’ve been going there over 40 years and only just managed to crack on to this shack. Real estate was going nuts here. I wouldn’t bother mate.
was just curious where the shack was , if we were to move there I would be up in the hills towards Birdwood ....
Bottom of Yorkes Peninsula, Innes National Park, Pondalowie Bay.
Bit of tidy up painting today between mowing and wipper snippering. Some how missed a section of bonnet edge as well as part of the tailgate hinges. Tray opening got scratched when I was fitting the ply floor so painted it and inner tailgate. Fair bit of masking necessary to avoid overspray.ImageImageImage
Im very happy with the tonneau cover I got from Tonnos 'n' Stuff. Thanks to Neil for the tip. After fitting the tabs I had to adjust six of the 17 floor optimal fit. I found they could be moved one way or another up to 8mm from first location. Now it has been on for a week it has settled to a perfect fit.ImageImage
Never been much of a fan...Image
Nah...... Yeh.......Nah 😗
Go the chrome bird......👍
