J's EK doin some foolay siek skidz bro (vid)
TAYZ 58
Post by TAYZ 58 »
J,
Yr EK is looking real nice. Have you thought about some flappers for the wheels at all? Would look real nice, just a thought, you may not like them. Keep up the good work!!
J
Post by J »
TAYZ 58 wrote:J,
cheers man, I was thinkin thin whites...
but im waiting for some 14x6 dragways to pop up, then i will polish them and put thin whites on them
NoMAD
Post by NoMAD »
nice job J, will be an interesting change for non FB-EK lovers to pick which is what i love to see (and do!)!,
hows the boot coming along?
any plans to cover the corners where the board joins? you might be able to make a little profile wedge or something....just a thought...still looks good mate
NoMAD
J
Post by J »
thanks nomad,
plans are with the boot is to just upholster it, I kind of like the box look of it all. I just need to make little pieces to cover that top gap you can kind of see in the pictures.
I just have to tidy it up for the hot rod show in a few weeks, trying to get this grille done!
I took my numberplate bullets and filled in the holes on the bumper, then I ran out of bolts for the rear numberplate so thats in the rear window :P
Very neat trick, should keep quite a few guessing!! Now come where's this grill?
J
Post by J »
in the process of being made, but the dude is in africa so i might send him an email and get someone else to help me out
paroharo
Post by paroharo »
J wrote:I dont know how I am going to make a square inside a square without cutting a line from the big square so I can make a little square... get it? :lol:
If you drill some holes at each corner of the "little square" ie the door, say 12mm, enough to fit a jigsaw blade in, then you can cut out the little square inside the big square.
That's if you really want doors...
Hope this helps
Jon 8)
J
Post by J »
paro, you are officially the smartest man alive!
your right up there with the dude in the wheel chair with that computer voice :P
thankyou!
yes i want doors on it, might get some shiney door knobs too :)
stinky
Post by stinky »
If you want to save the smaller square to use as a flush fitting door, use a drill bit a little larger than your hacksaw blade. Drill a row of 3 to 4 holes along the cut line, then work the drill carefully to connect the holes, this should make a slot large enough to get jigsaw in.
If you get it right, you can use both pieces of timber, rather than having to cut a separate door.
J
Post by J »
stinky wrote:If you want to save the smaller square to use as a flush fitting door, use a drill bit a little larger than your hacksaw blade. Drill a row of 3 to 4 holes along the cut line, then work the drill carefully to connect the holes, this should make a slot large enough to get jigsaw in.
you are also smart Mr Stink :P didnt think about re-using the thingo!
(AUST)Mod
Post by (AUST)Mod »
Well J, I think you are back to school today. Just wanted to say that you made great holiday progress, and I can't wait to see the boot done. Want to do mine next? :wink:
J
Post by J »
(AUST)Mod wrote:Well J, I think you are back to school today. Just wanted to say that you made great holiday progress, and I can't wait to see the boot done. Want to do mine next? :wink:
hahaha cheers Andrew, for some reason I never see when someone posts on my topic :?
I can help you not make the same mistakes I did haha, and you can use my boot to shape/cut etc.
Anyway I have some other updates, Tool a trip out to Armadale for some small items, was tossing up getting new headlights, dont know why i didnt?
where'd the bullets go?
i think the flat ones are better, makes the change less noticable :P
nice door lock pins :)
crooked chrome surround for gauges (crookedness fixed now)
before
after
Not all turned out this good, so I went ahead and painted them to match the new carpet which is coming soon.
J
Post by J »
BOOT = FINISHED!
STAY TUNED, IM GETTIN HORNY!
take that whatever way you like, but next weekend you will discover why :P
(AUST)Mod
Post by (AUST)Mod »
A guy called AL is making him horney bahaha
J
Post by J »
(AUST)Mod wrote:A guy called AL is making him horney bahaha
there are also some italians involved :P
