LS1EK
TAZ
State: TAS
Re: LS1EK
Post by TAZ »
CHOPPED wrote: Thu Jul 04, 2019 2:10 pm hey man sorry mate
just seen this pm :roll:
yes i put a piece of 200 dia by 10 mm scallop in there and welded it in
engineer looked at itwhile still in its metal stage and just laughed and said
fark overkill :crazy:
carry on man
looking good :thumbsup:
Paul
🤣🤣🤣 from a boilermaker I reckon you nailed it 👍👍
TAZ
State: TAS
Re: LS1EK
Post by TAZ »
Managed to get some time to finish off the front chassis rails and repair the last bit of rust. All areas are sprayed with rust converter and then copper coat.
The front cross member was cut from a section of 100x50x3mm RHS. I kept the original top flange and then fitted and welded the new section in.ImageImageImageImageImageImageImageImageImage
Sent from my SM-J730G using Tapatalk
Re: LS1EK
The tidy work continues. That radiator support won’t rust out in a hurry.
TAZ
State: TAS
Re: LS1EK
Post by TAZ »
Errol62 wrote:The tidy work continues. That radiator support won’t rust out in a hurry.
Your too kind. I reckon it will see me out and be ready for a electric motor conversion for when my kids take ownership of the car.
CHOPPED
Re: LS1EK
Post by CHOPPED »
very nice work man :thumbsup:
you have done the same as I did on mine
i braced the entire subframe with 5 mm sheet from radiator support right back to the y frame where it bolts up
keep the updated going
im enjoying the progress
Paul
HEY IT WASNT ME
Re: LS1EK
Great Fab work as usual TAZ
This is a great custom build
Re: LS1EK
Love what your doing Taz keep the photos coming mate
TAZ
State: TAS
Re: LS1EK
Post by TAZ »
Motor, box and front end is back in. Gained more clearance for the headers and made the radiator cross member so it is removable. It was welded in which caused issues with getting the motor out.ImageImageImage
Re: LS1EK
That looks a lot more elegant than the "hole in the guard" fenderwell headers. Well done.
Re: LS1EK
Schmicko!!! :clap: :clap: :clap:
BS
Re: LS1EK
Post by BS »
Looking good
Sent from my SM-N960F using Tapatalk
59wagon
Re: LS1EK
Post by 59wagon »
Great fab work Taz. Does the engineer have any issues/requirements when it comes to modifying the chassis like that?
Keep it up.
Cheers, John
TAZ
State: TAS
Re: LS1EK
Post by TAZ »
59wagon wrote:Great fab work Taz. Does the engineer have any issues/requirements when it comes to modifying the chassis like that?
Keep it up.
Cheers, John
The section that is notched has been laminated etc. At this stage the engineer has said nothing about it as he has not seen it ImageImage But my 20 years experience as a boilermaker welder tells me that structurally there should be no issue. The remainder of the chassis from the section which has been notched has also been laminated with 3mm steel so once again I see no issue.
TAZ
State: TAS
Re: LS1EK
Post by TAZ »
Look no hands ImageImageImage
Re: LS1EK
:thumbsup: :thumbsup:
