Decided it was time to put fluid into the brakes. Filled it and let it sit overnight. Came back to a puddle of fluid on the floor... I had the various flare nuts tight, but not tight enough. Nipped them up, repeated process and no leaks. So far, so good.
Bled first caliper (both inboard and outboard pistons have bleed nipples) but soon realised that the horizontal calipers were not going to bleed. Normally I would unbolt the caliper, turn it so that the bleed nipples were vertical, put a block of wood in between the pads, bleed, then refit. Of course some idiot had put hardline all the way through the brakes... no hoses, so hard to tilt the caliper back.
Did some thinking for a few days. The young bloke suggested tilting the entire chassis up on the rear tyres (no motor in), but that didn't sound like much fun
Came to the conclusion that brute force and ignorance might work. Unbolted the calipers, tilted them around the rotor until they were vertical, letting the brake lines bend/flex. Success! Bled one side, lots of air out, and brakes getting harder. Started thinking I was on the home stretch. Left it overnight, came back to more fluid on the floor. Looked like the caliper seals were blown
After much wiping and checking, worked out that the brass NPT-to-inverted-flare fittings I had screwed into the calipers were weeping. I had them tight, but again not tight enough. Brake line off, spin brass fitting one more revolution, refit brake lines, unbolt caliper, bend brake lines to vertical again, bleed caliper. Clean up mess, wait overnight... no leaks
Move to second caliper. Realise that to spin that brass fitting I was going to leak a lot of fluid. If I was unlucky, I would put air into the other, bled caliper. Remove master cylinder reservoir cap, put a ziplock bag over the opening, refit cap. Now if it leaks, it will pull a vacuum in the reservoir and only leak a little. Perhaps.
Remove brake line, ignore leaking fluid, spin brass fitting one more revolution. Look up and see brake fluid level in reservoir nearly empty. Need to work faster. Covered in fluid, brass fitting on different angle to previous. Have to flex brake line to line it up. Try to refit brake line. Feels OK, tighten. Faster, faster! Job done, top up resevoir, clean up terrible mess. 'Out of time, kids need feeding, let it sit overnight and bleed in morning.
Came back to another puddle of fluid on the floor. My haste had let me cross-thread the brake line into the brass fitting.
. Remove brake line and cap off rest of system, remake new brake line, replace brass fitting, refit brake line, bend caliper up to vertical, bleed. Clean up mess again. In the end I got there, brakes actuate well, brake handle is firm. Definitely did it the hard way though
On an easier note, made up the windshield for the cowl from some 1.5mm polycarbonate sheeting. Still has the protective film on it, but is clear once the film is removed.
- FED windscreen 2.jpg (703.14 KiB) Viewed 5079 times
- FED windscreen 1.jpg (889.14 KiB) Viewed 5079 times
