BILLY BLACKARROW
Post by BILLY BLACKARROW »
Let it down carry a pump and pump it up IF you need it :grinnn: :grinnn: :grinnn: :lol: :lol: :lol:
BILLY BLACKARROW
62ekute
State: ACT
Post by 62ekute »
Errol62 wrote: Sun Oct 11, 2020 5:50 pm I did it
and now you don't need to fabricate that pesky clamp
Good point about getting it out. The timber floor will be removable, which is probably the only way. This also enables running a fatter tyre as I have left the rear bearer out.
Carry a small compressor - let the air out of the spare when taking it out then re-inflate.
If you make the floor a lift up from the spare wheel stop rail back you can take it out that way easy enough and give you better access and storage in and around the spare for jack and tools etc.
Errol62 wrote: Sun Oct 11, 2020 10:51 pm Good point about getting it out. The timber floor will be removable, which is probably the only way. This also enables running a fatter tyre as I have left the rear bearer out.
I want my floor in one piece so it looks original but will be liftable. Just need to remove everything from the tray, which isn't always ideal on a trip.
Fitting up gaskets to mount guards. I reused the rubber on the edge of the plenum cover and adjacent door. Used a piece from Clark Rubber to make a replacement gasket for the inner guard and glued in place with contact.ImageImage
Badge came also from Rob. I'm pretty happy with this. It looks great. I will cut and polish the tailgate a bit more before I put it on.Image
Looking good. I didn't even know there was rubber on the corners/ends of the plenum for the guard to sit on. Thought it was just mastic. Something else learned today😀
Me either until I started dismantling this car. The guards had never been off. The stone tray will get mastic but all the contact points for the guards have gasket apart from the body braces and rear bottoms, which I’ll try and get some mastic into. That re,Indus me I didn’t use it on the door hinges. If I think of it I will probably try and unbolt one hinge at a time and squirt some in there.
Don't drop this tailgate badge this time :roll: :lol: :lol:
Looking great mate :thumbsup:
Finally got some time and completed fitting the passenger guard. Pretty sweet although the bottom line up to sill fold is a bit out.ImageImageImageImageImageImage
BILLY BLACKARROW
A Blind man on a galloping horse would be glad to see it ----- Tell them that's how it came from the factory :grinnn: :grinnn:
BILLY BLACKARROW
They were all the same, some better than others !!!
Don't stress Clay, very hard to notice when looking down at it. Its coming along nicely ! Your endurance will be tested when you decide to cut and buff it !
59wagon
Post by 59wagon »
Hi Clay, you're still flying along with this mate. Great job.
John
