Really flying along there Clay you will have it on the road in no time.
Much awaited wheel cylinders arrived. One guess what size heads on the bleed screws I obtained.
Here’s a curiosity
The hand brake cable to backing plate mounts are marked L & R. Well some are. No obvious difference but oh well guess I’ll reassemble accordingly. Sent from my iPhone using Tapatalk
With the original felt gaskets I salvaged.
one has gone missing now of course.
one has gone missing now of course. Sent from my iPhone using Tapatalk
Rears on, fronts assembled.
The brake guys told me they use kopr kote on the adjuster threads and a smear around the inside of the adjuster lid. Just be sparing with it and don’t let it near the pistons.
The brake guys told me they use kopr kote on the adjuster threads and a smear around the inside of the adjuster lid. Just be sparing with it and don’t let it near the pistons. Sent from my iPhone using Tapatalk
drivers side rear installation complete. Sent from my iPhone using Tapatalk
Nice work, mate
Passenger side rear completed today. Next job hook up the handbrake cable. I have a replacement for the pull handle which is broken. Threw some elcheapo black enamel on it this evening. The front cable is good but the adjuster threaded rod is bent slightly and won’t turn. It will all have to come out. Fun fun fun. Waiting for paint to dry on front backing plates before I do the front brakes.
Can’t believe the $1 finish on the handbrake bracket:
$1.99 on special at supercheap
Hang on
NOT suitable for automotive use wtf?!
NOT suitable for automotive use wtf?!Sent from my iPhone using Tapatalk
Bloody hell, Clay, does that mean your brakes might fail?
Should be right, mate. It’s inside the car.
It’s ok mate I painted the backing plates with a superior product
- thebrotherj
- State: NSW
Looks like you’re having fun Clay
Did you work out why the Red was running hot before the starter gave up?
Something to do with only having about two litres of coolant in the system joe.
- thebrotherj
- State: NSW
Ha! That’s a relief then. Maybe try two gallons next time?Errol62 wrote:Something to do with only having about two litres of coolant in the system joe.
