The loooonnng term EK 2 door project
Re: The loooonnng term EK 2 door project
Will the whopper-stoppers go inside a 14" wheel, or do you need to run something larger?
Was always planning to go larger on this one Harv - I believe Jag wheels were 15" originally so not a big problem - biggest problem is can I run them as I don't want to use Jag brakes on the rear.
A question for the engineer.........
The Jag stud pattern is HQ, Chev.
Forgot but what diff you running in the coupe ?
EK283 wrote: Thu Dec 04, 2025 11:22 am The Jag stud pattern is HQ, Chev.
Will be a Borg Warner 78 with the stud pattern changed to HQ/Chev
Blacky wrote: Thu Dec 04, 2025 11:47 am
So balancing the caliper size or slaves will sort the brakes. I did have a chart with all dimensions of brake piston sizes but cant find it at the minute.
Brakes are a balancing act !!
Yeah I have a Jag diff that came with the front and as a job lot but I have advertised it for sale - not interested in trying to fit that behemoth underneath an EK - should check the piston diameter on it I guess before it disappears.
Yes they are a dana 44 very strong diff, i have one in a studebaker LSD factory.
The jag rear ends are pretty to look at !
I am interested in what you end up concocting with the front end, factory suspension seems to be the best performers for our mixed roads.
A little more work on the 2 door , modified the door inner so the door trim goes all the way to the floor
Welded up the seam in the front guards as well
funkyscooter
Post by funkyscooter »
Nice work Blacky - never thought about dropping the door trim. Is that to make the door feel not as long/skinny visually?
And welding up the guard seam! Have been planning to do that but started having second thoughts that maybe its a part of the charm of the car. It is such a weird body line, wonder why they never filled it in the first place. I'll sit on the fence for now.
Scott
I thought the same when I did the ute Scotty.
Saving some weight I suppose. Years ago a mate had this EK he cut metal out everywhere to lighten it. Had a GTS 186S and Saginaw box Volvo diff. It went.
Saving weight
Having a day on the 2 door today, changing the subframe out to double check dimensions. The original bolts came straight out surprisingly enough
Looking underneath it while pulling the bolts out - some of the welding I did , a quarter of a century ago ImageImageImage, looks a bit average
Thats ok Blacky, you will be rewelding in a Brace under the hump, my engineer wanted that in place, you may be lucky and yours not notice.
Otherwise its looking great.
Or a hydromagic tunnel
Errol62 wrote: Sat May 16, 2026 8:17 pm Or a hydromagic tunnel Image
I have a hydro tunnel -VERY difficult to find over this side of the swamp , and was thinking about installing it rather than whats in there now, the jury is still out
