Shed find ute
NoMAD
Re: Shed find ute
Post by NoMAD »
nice find Gaz.
Nathan
Foundation Member
WesternWagon
Re: Shed find ute
Post by WesternWagon »
Shed extension done
Finally got some much needed time on the ute, engine at the machine shop
Steering fitted
Chassis done
And a spare for NeilImage
Diff centre kit ordered
Started on brake lines
Member : Holden Car Club WA.
:ASRF Member
Re: Shed find ute
Good to see you’re back in to it. Nats are getting closer.
WesternWagon
Re: Shed find ute
Couple of updates
Mocked up the engine bay and interior
Just as well as the seat is too wide post trimming
:ASRF Member
Re: Shed find ute
Looking good - How did the seat end up too wide? Was it not the original frame?
Re: Shed find ute
Good to see you back at it mate.
I will give you a buzz re the chassis.
WesternWagon
Re: Shed find ute
FJWALLY wrote:Looking good - How did the seat end up too wide? Was it not the original frame?
Trimmer padded the sides
Seat is original
:ASRF Member
Re: Shed find ute
Ah I see - yes not much room to work with - hope it's an easy fix
WesternWagon wrote: Tue Apr 09, 2019 2:39 pm
Seat is original
Re: Shed find ute
FC speedo? I had to look twice.
WesternWagon
Re: Shed find ute
Picked up the 283 from engine builders, will give it a run in the ute, has a nice little bump stick and KB pistons Image
:ASRF Member
NoMAD
Re: Shed find ute
Post by NoMAD »
sweet should go nicely in the urge mate :thumbsup:
Nathan
Foundation Member
Re: Shed find ute
So you sold it.
Sent you a pm.
WesternWagon
Shed find ute
Woody came round and we did a Little bit more on the ute, running fuel and brake lines
Bloody hot in the shed
Callipers up to Advanced Brakes for some love in the morning
Image[IMG]https://uploads.tapatalk-ImageImagecdn.com/20191211/0a24f4b513c08cb0f929155b494a5752.jpg[/IMG]Image
:ASRF Member
Re: Shed find ute
Hard to see in the photos, but are the leaf spring u-bolts fitted with nylocks? I got pinged by the engineer for only having single nuts, and had to go back and refit spring washers.
That brake master and prop valve is pretty sexy. 8)
WesternWagon
Re: Shed find ute
Thanks Harv
Will be interesting to see how it brakes as I’m not intending to run a booster, have one just in case. Have a local crew here called Advanced Brakes that are a great help. Sorted my hotrod for me.
No they are just new nuts, single at this stage as I’m talking them off n on. Will be double nutted when completed
Gazza
:ASRF Member
