Installed new kits into both the Brake and Clutch master cylinders.
Went to bleed the clutch and brakes this afternoon.
Isn't it a great place they put the bleed valve on the clutch ?
Couldn't actually see the bleed valve, but could feel it. 3/8 AF ring spanner fits the bleedvalve on the booster and the extra clutch slave cylinder I had, so I assumed it would fit the slave on the car.
After twisting and trying several angles, I found the answer.
NO
And 7/16 was too big..........
Ended up disconnecting the slave and pulled it out completely so I could see why I could get the spanner on it. It's a 10mm one ???? Go figure. It looks like it has been replaced previously.
I can now add clutch slave cylinder to my list on items.
Got the brakes bled to the booster, will try to get the actual wheels bled tomorrow, and the clutch.
