Shed find ute
Re: Shed find ute
Nice work Gary,
Hey that dark blue EK of yours didn't originate in Victoria by any chance did it ?
59wagon
Re: Shed find ute
Post by 59wagon »
Your screaming along Gazza - good work.
In that last photo, how long would you have soaked those bits in citric for?
John
WesternWagon
Re: Shed find ute
Post by WesternWagon »
59wagon wrote:Your screaming along Gazza - good work.
John
Hi John
I soak them over night, you have to keep an eye on them best to start in the morning until you get used to it
Gazza
Member : Holden Car Club WA.
:ASRF Member
WesternWagon
Re: Shed find ute
EK283 wrote:Nice work Gary,
Could have done mate it was for sale as a project in WA about 6 years ago
:ASRF Member
WesternWagon
Re: Shed find ute
Pedal box finished today, waiting on my gold plated DD to Torana uni so I got to work on the engine. Building this one same as my hotrod, get it running then strip paint and reassemble
Headers, dizzy, carb and water pump all fitted, bit of trimming to get the VL radiator to fit.
Need to get it up on the hoist and Finnish chassis and cross member
:ASRF Member
Re: Shed find ute
Donk looks good in there Gary - will be a mean little ute.
Re: Shed find ute
Looking good Gaz.
I have had a similiar issue with the SBC I am putting in the guys FC Sedan for him, it was really close to the water pump pulley so had to notch the subchassis and lower radiator support to get it a but further forward.
Your engine seems to be sitting nice and low what sort of engine mounts are on the cross member mate the one this guy has in the FC seems to be a CRS one and the mounts are too high for my liking, I think the HEI dizzy and wiper motor are going to be an issue for me to overcome.
Re: Shed find ute
Looks good. I bet there are a lot of VL owners who which their top radiator tanks sat that high :lol: .
I used the VL radiator in my EK wagon. Had to lift it up whole radiator about 5mm to get that lower hose to clear the front subframe. Notched the top radiator support bar to bring the radiator forward, but still cant' fit a mechanical fan. Used two 10" Davies Craig electric fans in push mode. Had to notch the bonnet catch to get them up (they were too low on the radiator, and were cooling mainly the trans fluid part of the radiator).
WesternWagon
Re: Shed find ute
Harv wrote:Looks good. I bet there are a lot of VL owners who which their top radiator tanks sat that high :lol: .
Yes Harv I bout this one years ago after you sent me a pick of your engine bay
My Sedan runs the same radiator and has a notched upper support it runs a 16” Thermo
Can you remember what lower hose you used I used an XT falcon on my hotrod
Gazza
:ASRF Member
WesternWagon
Re: Shed find ute
FireKraka wrote:Looking good Gaz.
Cheers mate crossmember is CRS but I used a set of mounts I had for my Coupe
The HEI looks tight but the wiper motor will clear
It’s the same set up in my Sedan, can even remove the dizzy but I have to remove the cap first
I’m still thinking of using a cable system like I have for my hotrod
Cheers Gazza
:ASRF Member
WesternWagon
Re: Shed find ute
Back to the pickle factory
Covers are on
More updates soon
:ASRF Member
Re: Shed find ute
WesternWagon wrote: Sat Nov 17, 2018 6:02 pmCan you remember what lower hose you used I used an XT falcon on my hotrod
&*#@ Econovan 1984-1991/Mazda E2200 2.2L diesel top hose. Big one end for the SBC water pump, small the other end for the VL radiator bottom pipe.
WesternWagon
Re: Shed find ute
Thanks Harv
:ASRF Member
WesternWagon
Re: Shed find ute
Picked up a camper for the ute
It’s a 73 model but a quick trim it Will do nicely
Now to try Finnish the ute before the NatsImage
:ASRF Member
Re: Shed find ute
Styling gaz
