Classic scope creep project escalation Bones
Postie came with a parcel. Not for me, bugger, but he is an ex-panel beater so came and had a look and said let cure 4-5 days then smooth out run and dry patches with 1200 prior to buff, which aligns with my thinking.
Alex from Seatbelt Solutions rang to confirm details and belts are now in process.
Then the courier arrived with my tonneau. Okay now I’m even more excited but will put to one side until paint cured and rubbed, maybe.....Image
Thanks very much to neil for putting me on to these guys.
The blue sparkles a bit more out in the carport. Roof will need some rubbing.ImageImageImage
Looking good Clay. You must be very happy.
thebrotherj
Post by thebrotherj »
You must be over the goddamn moon, well done Clay! Hope you've upgraded from Coopers Sparkling to actual sparkling for the celebrations, you definitely deserve it mate. Looks fantastic.
Joe
Thanks you two. Resisted the temptation, but it is wife's birthday today and we will be having a few of these.Image
thebrotherj
Errol62 wrote: Wed May 13, 2020 5:18 pm Thanks you two. Resisted the temptation, but it is wife's birthday today and we will be having a few of these.Image
That's the spirit(s)!
Seatbelts are on the way Image
Now paint is on shell I'm fisholening inside box sections.Image
Robo
Post by Robo »
Awesome job Clay....You would have to be proud of that !!!!
Cheers- Rob
Thanks Rob.
Now you know I don't like to get ahead of myself all that much so you'd be surprised to learn started fitting the tonneau, although paints not even cured, let alone buffed. I had to go to Mitre 10 for 3/4" plugs for the Fisholene holes and ended up getting some 10mm bar for the tonneau bow. $3.75 for two metres, bent up in the vice, May be a bit high in the middle.Image
BS
Post by BS »
Haven't logged in for a while but wow you've been busy. Looks good
Sent from my SM-N960F using Tapatalk
BS wrote:Haven't logged in for a while but wow you've been busy. Looks goodImage
Cheers BS. WFH rocks! I had hoped to make Toowoomba nats before they got cancelled but had more or less given up.
Tonneau is fitting up ok but some of the post holes are a bit flogged out. Will have to get some of the magical sikaflex and stick little bits of sheet behind to act as captive threads where accessible. I will fit the gate up and pre-drill the new skin prior to paint as well.
More warm weather next week so I can paint dash and engine bay.
You can get bolt threaded posts Clay and pit a washer and nyloc behind it to be more secure - just touch up holes after youve drilled them out - much nicer fit - looks good though
Thanks Rob,
I heave seen the machine threaded posts. Pretty exxy as I recall, but might have another browse yet. Old dad from tonnes and stuff reckoned that dikaflex would do the job. We shall see.
