WA fb special
mph
Re: WA fb special
Post by mph »
NoMAD wrote:
mph wrote::thumbsup:
Im not sure what colour for the steelies yet,
Id like white steelies but not sure its look alright with the white wall , it might be to much. not aloud blackies :cry:
was maybe thinking a off white or cream or a grey like gun metal any thoughts
chromies :D :thumbsup:
i have no rod at the moment for my bench seat so that may just give me a option :clap:
looking good man, must be a good feeling having a drive...
Nathan
ill try get a pic for you mate 8)
FB-Special
Big block 161 :lol:
Holley sniper EFI.
Ek auto column shift.
Lj diff and reverse lights.
WA FB~EK Car Club Member.
Re: WA fb special
Visors don't have a bush but you should be able to make them sit by tightening the clamp screw. Image
Sounds like your doing everything right for the horn to work. Mystery.
Re: WA fb special
Im not sure what colour for the steelies yet, My choice would be some period hubcaps with body colour rims , what size are they , 14 or 15 inch ??
was maybe thinking a off white or cream or a grey like gun metal any thoughts :?:
Horn button issue with the steering wheel off i should be able to bridge a wire from the steering shaft to the gold steering contact ring and the horn should sound?
1. i have continuity from the gold column ring to the tan wire at the horn
2. i have continuity from the column spline to the ignition switch,door switch,sill scuff plate screw any bare metal i found
3. i have continuity from the steering wheel splines to the little gold spring contactor in the steering wheel when pushing the horn button as per normal operation to sound a horn. (wheels of the car)
4. i put 12v from the battery straight to the horn and it works - to which contact ??? Red or Tan ???? If you earth the tan wire at the horn does it sound ???
5. i put a wire from the gold ring to the shaft spline and other earth spots and nothing
6. The red wire at the horn has 12v sitting ready as it should i believe
Any more ideas
Regarding the coil with the red motor, the original coil wire i used as a trigger wire on a relay and ran a solid 12v through the switched relay to the coil now but the car wont shut of with the key im sure it used to shut off with this set up but its been a fair while since i last had it running . any ideas ? may be getting a backfeed from the alternator - a diode might sort that out ?
With the internal sun visors do they have a bush or something between the roof bracket and the visor shaft? mine keep dropping down.
Thanks gang
mph
Re: WA fb special
Post by mph »
Any more ideas
Thanks gang
The rims are 14 hg or ht with the rear reversed so it would have to have some center caps that would fit them not a fan of hq though
For the horn test itself it was out of the car, i had just scrap figure 8 cable from a battery to the horn on the work bench but ill try your idea out.
After doing some 12v diode research on the net you might be onto it blacky :thumbsup:
FB-Special
Big block 161 :lol:
Holley sniper EFI.
mph
Re: WA fb special
Post by mph »
horn works :think: weird that the car would crank over and run but seems the battery didnt have enough kahunis to crank the horn or the horn what some what seized and needed a few good solid blasts to free it up and blow the webs out. after doing other things to the car for a bit and having car running the horn is back in action with car on or off.
When i was re wiring the car i ran a new pink wire to replace the original pink coil wire thinking it was a resistive wire but it wasnt later found out thats later holdens but its done now also ran a new red + down to the coil .i had the pink on the dizzy and red on the coil. i tried some diode relays with no luck so i canned the red wire, the dizzy and coil run together now on the pink wire and the car starts and stops as it should now with the key. i tonged the pink wire its around 2a-3a so shouldnt cause any burn issues :thumbsup:
Cheers gang
FB-Special
Big block 161 :lol:
Holley sniper EFI.
Re: WA fb special
That's typical logic defying early Holden electrics.
mph
Re: WA fb special
Post by mph »
Errol62 wrote:Visors don't have a bush but you should be able to make them sit by tightening the clamp screw. Image
awesome thanks mate :thumbsup:
Awesome thanks mate :thumbsup:
FB-Special
Big block 161 :lol:
Holley sniper EFI.
mph
Re: WA fb special
Post by mph »
The front seat wire.
FB-Special
Big block 161 :lol:
Holley sniper EFI.
mph
Re: WA fb special
Post by mph »
Any ideas how to remove this last nut on the hg bango diff , its spinning the nut and the thread rod together but not removing itself.
FB-Special
Big block 161 :lol:
Holley sniper EFI.
ekstevo
Re: WA fb special
Post by ekstevo »
I gather you haven't got a gas axe? If you have an oxy acetylene put the cutting torch on and blow it away .
oz_ek
Re: WA fb special
Post by oz_ek »
mph wrote:Image
I'm guessing your only interested in the diff centre?.....If so, I would cut open the back of the housing, find another nut of similar size to the knackered one, tack weld it on top of the knackered one, stick your hand in the newly cut hole, spin the bolt, put some more weld on the new nut, now put some weld on the bolt from the inside, done!
Re: WA fb special
Centre punch the stud and drill out so the nut comes off would be tidiest. Hard part will be getting the bit aligned due to drill body fouling carrier and pinion flange.
This can happen when an early housing is converted to take later 3.08 or 2.78 carrier. A longer stud is required which can be achieved by means of inserting a bolt of the desired length but needs to be tack welded to the inside of the housing to prevent this problem.
mph
Re: WA fb special
Post by mph »
Yea im just after the center out of it . the center put in the lj diff in my fb is no good.
With the tyres size, trimatic and 3.55 ratio i wasnt to keen on having a longer ratio, but are these diff centers with longer lower bolts 3.08. The diff from a 6cyl manual hg panel van
im going to try drill the nut off
FB-Special
Big block 161 :lol:
Holley sniper EFI.
oz_ek
Re: WA fb special
Post by oz_ek »
[quote="mph"]Yea im just after the center out of it . the center put in the lj diff in my fb is no good.
im going to try drill the nut off[/quote
The long bolt housing will have either a 3.08 or 2.78 centre, the ratio should be stamp on the pinion flange/cover.
Re: WA fb special
That ratio is probably out of a Torana auto so welcome home to your LJ housing. HG 6 van would have been 3:55 or 3:36 originally. I've run 3:08 behind 192 Aussie 4spd and 3.3 trimatic in my sedan very happily. EK and torana about the same weight and wheel size.
