Grecian White/Apache Red 225
graham
Post by graham »
Really hate to be picky but the Z9 filter is used a lot by F**D.
Graham
Great job on the car
Craig Allardyce
Post by Craig Allardyce »
Thanks Graham,
I'm really surprised it took this long till someone would say that! I had no real options as the Z9 was the only filter available with an anti drain back valve and an anti syphoning valve (vertical mount), plus the thread size had to match the filter housing. GPM, micron and beta efficiency ratings were another issue with the full flow conversion.
Anyway I was a bit over with the potential free advertising for Ryco and the fact that the filter sticks out look a sore thumb so I ordered a billet cover for it. Looks better I think and matches the rocker cover. Think I'll have to polish the rocker cover a bit more though.
Bluehaze
Post by Bluehaze »
Wow. I can't think of any other accessories you could get for your FB Craig.
-Oh yes, one of those over-priced, in-accurate, battery draining clocks!
Craig Allardyce
Re:
Your on the money Richard. It's funny, they never appealed to me, it never came with one, and I'll never fit one, especially for what you'd have to pay for it. I guess my FB will be the paupers model. :lol: :lol:
Craig Allardyce
Whitewalls on today...woohoo!
Kitted out master cylinders and ready to bleed brake and clutch. Purple brake fluid????????? Looks a bit gay but it should brown off (Silicon fluid). All mechanical finished underneath bar oils in box and diff.
Still waiting for my outer door seals......getting annoyed with this part as I need to fit them before the doors go on.
Temporary trim should be ready to fit Friday week. Not much more left but a lot of fiddly shit to tidy up and finish.
Craig Allardyce
SunnyTim wrote:
Craig Allardyce wrote:Your on the money Richard. It's funny, they never appealed to me, it never came with one, and I'll never fit one, especially for what you'd have to pay for it. I guess my FB will be the paupers model. :lol: :lol:
I agree there's heaps of accessories I'd chose before a clock - fiestas, spats, stainless sills, taxi rail and a picnic shelf to name a few.
My brother has a camper seat but wont let it go, but also wont do anything with it.... :evil: :evil:
Craig Allardyce
My pink EK was dealer fitted with a camper seat and a taxi rail work that out :shock: don't wake up in a hurry :lol:[/quote]
I had a FE sedan many years ago that had a taxi rail. I always wondered how many teeth were smashed out on it over the years :gasp: :lol:
Craig Allardyce
Its been a big week as I've finally got the car driveable. I had a few dramas with the brakes due to leaks from the silicon fluid but all sorted now. Clutch was a real bastard to bleed as the master cylinder piston would not return after full travel when bleeding down the slave cylinder. After much stuffing around it was vacuum holding it down so I had to be patient with the piston returning after each stroke. All the interior is finished now but I'm still waiting on outer door seals. Betta Auto rubbers sent me a mix of outer seals with two different types of profile on the lower section that runs across the scuff plate. I discovered this after fitting the first one. After some calls with them it seems that they cannot supply the lower section as per the original profile and are searching for another rubber supplier. The only one they can supply is a new type with a "K" profile. In their words its a double lip. In my words its useless as it doesn't have a flat section on the inside face of the lower profile and cant be glued to the scuff plate properly. Well that was some months ago now so you can guess how happy I am with that! Now I'm looking for a refund and the possibility of going for Rare Spares Seals and we all know what they're like.
Another problem cropped up too. No vacuum wipers. My new Trico Motor is stuffed straight out of the box. Looks like the vacuum flap seal is passing. Probably dried up from age. I also found the vacuum pump kit I bought has the wrong valves. The spring tension on the valves is too tight to allow the pump to draw enough vacuum. I ended up pulling it down and removing the new valves and found some old ones that weren't leaking down and fitted them. Wipers are good now with 12" Hg at the motor with only the pump supplying vacuum (manifold disconnected). I've temporarily fitted an old motor that worked ok so I'll get to sorting the "new" one out later.
If you bought a kit with these valves in them don't use them in the vacuum pump!
Leave the old ones in if they don't leak back, or source new ones of these type.
bootlegger
Post by bootlegger »
The rare spares door rubbers are pretty good now. You dont have to slam the doors anymore. They still arent identical to factory but doo look right along the bottom.
I did find the Rares rubbers pretty good, but I'm not real anal about those things.
The doors had to be shut pretty firmly which I thought was a good thing to keep the rain out.
Although I can't believe how much water got in at the Sawtell nats with such tight fitting door seals :roll: .
You will have to have a meet up for the Vic forum folk to come see your finished car, weather is only getting better from now on.
Trevor.
Craig Allardyce
Thanks Dave and Trev for the advice on the door seals.
Yep, will do Trev. I still have a fair bit to go, and a lot of fiddly shit, but will look at meeting up sometime hopefully late October. I've noticed the Victoria postings have been pretty quiet since June so I'm expecting a bloodrush soon with everyone busting to get out in their cars when the weather is better. I know I am! :glasses:
WayneXG95
Post by WayneXG95 »
Mine sound like a golf... 8)
Craig Allardyce
A few more pictures today for all the gawkers! :tongue: :tongue:
I'm staring to realise you can only drive up and down your driveway so many times before your other half thinks you've lost the plot! :wtf: :wtf:
Craig Allardyce
And some more. :thumbsup:
So close! Looking good.
