Tigers V6 Conversion
nes138
Re: Tigers V6 Conversion
Post by nes138 »
AFAIK you are not allowed wheel spacers for rego. stick on a crap set of legal tread wheels and use spacers after....Make sure they are steel and NOT aluminium :angel:
michaeljohn1234m
Post by michaeljohn1234m »
Air con is finally in with no room to spare
and no ash tray as will. Just the lid and i had to do the same with the old heater controls too
cut some holes to put the heater hoses through to keep them away from air hoses and everything else as they do get hot' I double plated both sides to keep the strength in it (sending photos to my engineer to see if he's happy with it)
the bulkheads make it easy and the Air o crimp system is so easy
put the wheel on to have a look
now to finish off the inside wiring etc
found the wheels i want
spoke to Australian Classic Wire Wheels about the LA Custom wheels and i can get the two different offsets that i need (i can get rear 17'' x8'' with 40P & front 17''x7''with 26P) he's just seeing if i can get them with gold wire spokes
has anyone hear about these L A Custom wire wheels (good or bad ) I'd like to know before i order them
http://www.acww.com.au/
michaeljohn1234m
and the rims aren't deep dished like those ones
Looking good mate, I had LA wires on my '64 Chev, I was a bit worried about them when I first fitted them , used to check them every time I drove it as I was paranoid about them coming loose and falling off with the knockoff setup but they stayed tight - never had one come loose and I did thousands of miles in that car.
oldnek
Post by oldnek »
michaeljohn1234m wrote:Air con is finally in with no room to spare
a
Warning, Warning. Help Will Robinson, Dr. Smith, I'm stuck behind this dash!
Gee Wizz, is there room for the wiper linkage and wiring..... Pretty tight indeed.
michaeljohn1234m
it's tight but yes the wipers work fine
a
:lol: :lol: :lol: :lol: :lol: :lol: Ya hadda be there :thumbsup: :clap: :D :D :D
michaeljohn1234m
Had hoped to do the headlight wiring and air con pluming so i could put the guards back on, but the wire i ordered (25amp) didn't come. so i started doing the air con pipes,started off fine at one end.
other end started out alright
then it didn't quite fit right
two cups of tea later,a total re do of the heater hoses and it came out better then planned
a couple of new holes and cut the square bulkhead in half,and just have two holes to fill in
all well away from the wheel (that's an 8" wheel ) when finished the front wheel will be a 7"
all the work that will never be seen
and the VX heater hoses fit great ( just shorter)
now i need to know is the top hose (coming from the engine) the one the water comes out of
Cogburn
Post by Cogburn »
Great job on the AC plumbing!
I always enjoy your updates and photos.
michaeljohn1234m
thanks Cogburn
can anyone tell me which hose is the one to put the shutoff valve on VX motor (top or bottom)
FeeBee
Post by FeeBee »
you'd have to but some Perspex panels on the guard so you can show off your handy work!! Looks good :clap:
michaeljohn1234m
I was thinking the same FeeBee
these are the rims I'm thinking of getting 17''x7'' front and 17''x8'' on the back (but from LA Custom)
oldnek
Post by oldnek »
michaeljohn1234m wrote:I was thinking the same FeeBee
I wouldn't get them, they rust in the spokes and are a absolute bugger to clean.
Marko
Post by Marko »
Know its not a sedan but this might help your decision mate!!
P1020189 (640x480) (2).jpg (213.61 KiB) Viewed 1668 times
FBVANDAM
I had a set of 100 spokes on my '64 Chev, they were on there for 3 years and 12000 miles - I think I cleaned them once and they looked great when I sold the car :thumbsup: It had 4 wheel drums so that might have something to do with them staying clean.
