If I read your post correctly, this is the POR-15 "tank treatment"....?
It looks pretty flash - you'd be pretty happy with that.....?
I don't know if you had to strip the top of the tank - and this is irrelevant for a van, I'm guessing - but for a sedan - it would be necessary to fit "packing" in the recesses - the floor mat sits directly on the tank....
Looks great - hope it's POR-15.....
POR15 as a base coat?
POR
Am really happy with the outcome
it spent a week in the Acid Dip prior to the Tank Treatment being applied. the treatment has now sealed both sides of the upper part of the tank hence no moisture = no rust
If you can’t convince them, confuse them.
This should get you started SCOOBB: http://www.ppcco.com.au/
They do have local agents too - listed on the website or give 'em a call.
Cheers, Steve
Cheers, Steve
SC00BB.
I would also look at KBS coatings, I have used them and have been very impressed, much cheaper as well.
www.kbs-coatings.com.au
John
John
