efi 202
- ekdave1962
hi not sure what the pressure should be but removed rail and set it up on top of motor .. fuel coming out all injectors but no1 .. then only one i checked it plug for fuel but just checked the rest and there all wet .. im thinking is should have fired even if running poorly ..
off to work now so tomorrow im going to pull it all down (hopefully manual will arrive) and triple check it all again ..
man im so over this efi ..
starting to think carby again
Yer wait until you drive it with EFI, carby, what carby..... P.S. you are not on your own there at the moment
. Got to drive mine for about 30 minutes without stopping then dead
!!!! Something to do with the fuel delivery from the tank to the hp pump
... l'll attack again on the weekend and see what I find.
Whatever....:(
- ekdave1962
haha yeah i was suprised to read the kw out put of them was 109 verse a 308 at 119 .. wow
i wondering since i have injectors working spark .. not 100 % about the timing but i sure it close enough for to run maybe spark is too weak ?
there just not much else left .
the ecu is doing it bit adding fuel .. replaced the block sensors
only items are the air box and that other fresh air bye pass but wouldnt have thought it would stop it from running ..
have a spare ecu on the way just incase, but i need to get i back on road soon for a wedding so my even clean up the clapped out 173 and toss that in if everything else fails this week ..
ps is ther ea difference in coils as im running the one that was on 186
D
D
- ekdave1962
we were talking about VK stuff on the weekend the guy said the dizzy is basically empty with a sensor that goes into the bellhousing so there could be something in the dizzy, DON'T use a points coil with a electronic dizzy i melted one (shop sold me the wrong one
) and have heard of them exploding
not sure on the power figures
i've driven VK inj motors and cars with 308's it's chalk and cheese definately run smoother than carby
only the black carby dizzy is empty the pick up is on the back of the trans runs off the converter the efi runs the same electronic dizzy as the blue motors
i had a prob with mine and it was the dizzy it would spark when turnig the motor over testing it somthing to do with the comp holding a bit of power enough to give it a zap when cranked over but not enough to keep it running
changed the dizzy and it was all good again
the box on the side of the dizzys have a habit of just failing somtimes they tell me??it had me farked 4 days i had fuel and spark i thought what else could it be but that was the problem it just died in traffic one night
***just cruise***
***just cruise***
- ekdave1962
Well im pleased to report she was a goer today ..
finally took it for a spin this arvo .. still lols to do .
make room for air box means moving break booster
or adding a different filter .. extractor gasket leaks, just cant get in the to tighten last bolts .. wouldnt mind making a little more room as manifold still a little close to fire wall ..
so the problem Was ,, drum roll
2 fold .. changes coil and dizzy no difference ..
remove injector rail and fueled it up to find 1 & 2 injectors not firing, now this took me a while to work out would test leads with meter and test light all good, ? ran spare injector lead and the fired ? the end result was that the test light had spread the contacts so the didnt make the circuit .. but worked fine when tested with light and meter . hell easy fix ..
2nd problem i think was because it was only getting fuel in 4 cyclinders and i still had a few vacuum hoses off made it un runnable at low rev's
any way shes all running for now .. a little ruff eratic idle some what noisy with out a air filter . she goes well if u can stand the noise and pinging under full power ..
so thanks again to all that suggested idea i sure do have a good understanding of the efi now
ooh one last thing that air bypass that rruns air around throtal body when way is up .. ?
D
D
- ekdave1962
power out put figures seem had to believe
Holden Black 3.3L EFI straight six:
Capacity: 3.3L
Induction: EFI
Valvetrain: Overhead valves, 2 valves / cylinder
Bore x Stroke (mm): 92.1 x 82.5
Compression Ratio:
Maximum Power: 109kW
Maximum Torque: 266Nm
Holden Black 5.0L (later 4.9L) V8
Capacity: 5.0L (4.9L after June 1985)
Induction: Carburetor
Bore x Stroke (mm): 101.6 x 76.7
Compression Ratio: 8.8
Maximum Power: 117kW
Maximum Torque: 319Nm @ 2400rpm
http://holdenpaedia.oldholden.com/index ... lden_specs
Capacity: 3.3L
Induction: EFI
Compression Ratio:
