Knock out the front uni on an old tailshaft and keep the front bit with gearbox spigot.
Stuff it in the box and tie it off with wire when removing gearbox.. or motor and gearbox in one go from a car.. saves a whole lotta thilthy gooey 90 grade running all over your floor when ya tilt the thing down getting it out.
Yep ya can drain the box before ya remove it but its a bit like having a pee.. no matter how much ya shake and beg.... the last few drops run down ya leg
Reddo
Don't try fitting an after market flex fan to a red powered FB/EK they really do flex.....into the radiator It was always going to be a tight fit but i thought i had it sussed. No dramas in the driveway and out to the main road, but i thought i would give it a good thrash just to be sure and bang crunch. New radiator, stock fan and no more chasing small power gains...lesson learnt
I had one of those 6 blade fans on my green EK ute - 186.
water pump pulley bolts where about 12 to 15mm off the radiator core. fitted the fan ( has staino blades with very little pitch) no part of the fan stuck further foreward than the pully bolts....worked perfect .
Was your fan plastic , steel or stainless steel??
Reddo
Reddo it was a five blade fan with fancy blue centre and stainless blades.
the blades have a fair bit of pitch on them (engine side) which decreses with increased rpm. I think that force that flattens out the pitch with speed also flexes the whole fan away from the motor and in my case into the radiator. It was only the tip of one blade but was enough to wreck the rad Probably with some more fiddling you could get it to run ok, but the tolorance of the fan blades to the fan belt (engine side) at idle would be very very small to allow for the flex radiator side. Hope that makes sense
