Celica 5 Speed
You should be able to make one with your skills Mal? Trev 8) .
FB MAD
Post by FB MAD »
Have you looked at the CRS type trans tunnel or are you wanting to stick to the EK Hydromatic tunnel?
Malcolm
celica 5 speed
Post by Malcolm »
Used a gardner tunnel in the FB, but just wanted to use an EK auto tunnel in the next one as making the cross brace on the underside of the tunnel was a pain in the ass.
If I can't get one I guess I'll just do another A/M tunnel. When I had the box out of the FB I made a template of the tunnel just in case.
Malcolm W.
V8EK4us
Post by V8EK4us »
Did I here Chevy V8 mentioned :D :D :D :D :D :D top stuff Mal. I have an 80 series GXL cruiser that I shoehorned an EFI V8 and Turbo 700 into, the T700 is awesome, top gearbox and has the best O/D ratio of all the autos....... but for outright fun I'm running a 1000hp rated Powerglide with a trans-brake in the EK ...... :D :D :D :D that should be a hoot!!!!!
With the T700, I purchased a module from "Marks 4WD Adapters", I can, and have reprogrammed the gear changing it the box by the "DIM switches" in the module, works a treat, the cruiser drops (and locks) into O/D at 60KPH how I have it set at the moment. Uses less fuel than the old diesel and 5 speed that was in it!
