New Rocker Cover - Anyone know what it is ?
If you are serious about getting the most out of your rocket cover, you should consider fitting a set of exaddurators to maximise the horsepower gains from the rocket cover.
As you are probably all aware , the true hard core grey motor enthusiast wil also go to the trouble of installing some fangers as well, but they are out of the reach of all but the very wealthy. :lol:
Blacky wrote:you should consider fitting a set of exaddurators to maximise the horsepower gains from the rocket cover.
I have a set of those Blacky :D
Mine are enhanced with 'SNASCO' Double Overhead Underhangs :shock:
FB MAD
Post by FB MAD »
If you can find some NOS bottles of Genuine NASCO tap water, block your muffler up and fill it with said water.Leave overnight,drain, and your muffler bearings will recondition and be as good as new.
Terry.
ekv8ute
Post by ekv8ute »
You guys are too much.
My NASCO rocket fuel just doesn't cut it any more... :P
alloy rocker cover
deleted
Re: alloy rocker cover
But fundamentally, other than being totally different, they are identical and both will permit the engine to reach maximum output without need for state-of-the-art outer terestial additives to counter-act rocker cover short-comings including turbulence diversion, oil flow direction deceleration reversal or lifter noise ground force attraction .......
ps delete all technical relevance to fact in final paragraph.
Contents of final para will also (if diluted proportionally will H2O) and spread liberally will cause grass under your vehicle to become lush and necessitate unwanted attention by your mechanical goat - Victa
What The :shock:
Post by mrs ratbox »
one thing wrong with all that rosco his is a genuine kool '60's item yors is a later copy :roll:
rocker cover
deleted
southcoastkustom
Post by southcoastkustom »
Great pickup there Mephious...tried to buy that one myself for the blue van. Love that look also.. 8)
not too shiny thankyou.
Mephious
Post by Mephious »
Cheers all for the info.
I couldnt find any markings on the cover to state who made. If anyone has side plates to suit on a red block please let me know im very interested !!!.
I had to grind out the plate which sits under the vacuum outlet as it was fouling on the rolla rockers. Im crossing my fingers the cover will have enough clearence for roller rockers but wont know till it fires up. Its right on the line for a yay or a nay whether it will work or not.
Cross ya fingers !!!!
On a side note ............. anyone fitted a gilmer set to a red motor hahahaha. I know it wont look period to the cover but I have a spare set laying round in garage and it appears all the holes line up - water pump , alt and crank pulley.
Just not sure how its ment to fit to the crank pulley as it lines up with the 3 holes. Should these be tapped or is there room behind to fit a bolt/nut ? Never had to remove one before .........
smooth
Post by smooth »
Scott,
The three holes in the Harmonic Balancer are already threaded. You DO NOT place nuts behind.
Just make sure you get the correct sized bolts (in thread and length).
Regards, Smooth 8)
Mephious
Post by Mephious »
Ahhh cheers mate !!!!
Just checked and had to scrape a fair bit of paint away, thread was there ! Thankyou !
Redmotorspoweron
Re: New Rocker Cover - Anyone know what it is ?
Post by Redmotorspoweron »
Hey! Does anyone have a "Craig equip" rocker cover? And/or triple carby manifold? If they exist?
Looking to buy I live in sydney and am very keen to find them in original and possibly rough condition
