GPS speedometer advice
Re: GPS speedometer advice
Errol62 wrote: Sat Jan 17, 2026 6:23 pm
Mick wrote: Fri Jan 16, 2026 9:40 pm
Errol62 wrote: Fri Jan 16, 2026 6:28 pm Not the point, Blacky. GPS or GNSS, assuming use of Beidou, Glasnoss etc. as well as the original US military constellation, is as accurate as you can get, as long as you can see four satellites or more. Probably even work in tunnels now using “pseudo-lites”. It gives me confidence when I set the cruise and then go through a trap.
i've had 3 different GPS speedos reading 3 different speeds (2 apps on phone and 2 different actual GPS speedos) and all 3 also different to the speedo in the car, varied by 7kmh between the 4 and none worked in a long tunnel
No wonder you keep getting pinged mick 😆😆
Being a surveyor I have access to high level Global Navigation Satellite System receivers, 0.1kmh precision, which I have compared to a Speedo app, and google maps, both on the same apple phone. They all agreed to the kilometre per hour.
i've been "pinged" once in the last 10 years that was by an arsewipe in SA :roll: i knew i was speeding but doing a speed i have had absolutely no problems doing in NSW
ed.harris
Post by ed.harris »
I have the Tomtom set up that it beeps at me when I am 5kph over the speed limit.
Bit the bullet and bought $100 special from ebay. Arrived today. 110mm size fits straight in the hole and clamps up perfectly. Dont know if it goes ok, but certainly installs easily.
Unit on ebay
Unit on ebay
We need to get Blacky one of those 200km/h and 8,000rpm gauges for the rattler :ebiggrin:
Harv wrote: Wed Jan 28, 2026 4:57 pm We need to get Blacky one of those 200km/h and 8,000rpm gauges for the rattler :ebiggrin:
It might well see 8000 RPM........
....... once :econfused: :lol: :wtf: :wtf:
Very neat Brett. I wish they did them with the orange pie chart dial.
Blacky wrote: Wed Jan 28, 2026 5:31 pm
It would be the worlds most powerful FB/EK... for 1.4 milliseconds :oops: Imagine the sound of it winding up though... would put a Sikorsky turboshaft helo engine to shame 8)
Harv wrote: Wed Jan 28, 2026 6:31 pm
I reckon once its dialled in it will not make 1/3 of what Grosey's orange EK ute makes ......... :esad:
There is a 140km option but also with 8000 rpm tacho and 80mm diameter which is too small.
Quite happy to be able to read to 4000rpm at halfway point, which is common enough on my runs. Have been operating without a tacho for 12 months and will enjoy having that little one not taking up extra space.
Took it for a run today. Works well speedo is accurate to other gps device. Tacho is still a bit twitchy but adjustment is easy. For $100 it is a good bit of kit. Would probably go for black instead of chrome if I did it again.
That’s a neat fit Brett, looks great :thumbsup:
