In tank fuel pump
Re: In tank fuel pump
Cheers mate good luck
gledge
Post by gledge »
Ok fuel system wrapped up now just need engine to feed fuelImage
I hate blue fittings but seemed appropriate as a vent
gledge
Post by gledge »
6" Glen?
gledge
Post by gledge »
Not quite… close as possible
Looking great Gledge
looks tidy :thumbsup: whats the latest with the donk ???
gledge
Post by gledge »
Roller cam set up is sorted but the old cam spat metal on the piston skirts and scored the bores so it’s in getter power Honed .. should get block back late next week.. I just need to check pushrod length and try install offset head dowels to try stop the valves hitting the block
Mine will be getting an 18V power hone....
gledge
Post by gledge »
Big push for boxing day cruise… not hopefull but roller canImage
gledge
Post by gledge »
Roller cam done new rings bearings and 3/8 pushrods.. fingers crossed valve to block problem solved hopefully 5000 stall converter may make it hard to run in but we will see how it goes
To quote Arnie: "Come on! You can do it !"
how much fiddling around to fit those lifters mate ? Looks like the sideplate bosses have been milled down ??
gledge
Post by gledge »
Not too bad really mate just cut the bosses back and fit a bronze gear…
