Wiring a SW Tachometer
Re: Wiring a SW Tachometer
Thanks Harv, might be the go!
S
Took Harv’s suggestion and fired off an enquiry (no ability to send pictures) to Stewart Warner the other Sat evening, thinking I’ll probably not hear back. Bugger me got a response about an hour or so later saying there might be a wire missing but send the SW engineer some pictures.
Sent the pictures only to be told they don’t recognise the tacho. It must be an old one!! I may need a SW sender unit which is not made anymore so SW engineer suggested eBay!!
Back to square one with more head scratching :crazy:
Pulled the unit apart again and came to the conclusion the blue and green power the back light whilst the red and black go to a coil (via selector switch and various resistors.
In essence a moving coil meter where there is a pulse received from the dizzy side of the coil. So hooked it up and whacko it worked. Happy days. :thumbsup:
Good outcome 8)
