2021 Dunn Run
Re: 2021 Dunn Run
And VH40 boosting front brakes, rear unboosted?
Re: 2021 Dunn Run
I'm still trying to nut out what the catch-can is doing. Doesn't seem to be PCV as it's vented. Maybe only the rear rocker cover breather throws out oil.
60Special
Re: 2021 Dunn Run
Post by 60Special »
Factory grey v8 in my van too.
Re: 2021 Dunn Run
Some brilliant cars over there. You all better get over to SA next June...
Re: 2021 Dunn Run
I am pretty certain both circuits have to be boosted in NSW - well according to my local cert engineering guru anyway. I wasn't given a choice ( 7" dual diaphragm booster with dual circuit master) which of course means all sorts of firewall, bonnet hinge and pedal dramas.
Re: 2021 Dunn Run
That van is startlingly good. Making me think about a body coloured inner guard set up. Thinking, thinking, thinking....
Thanks for posting them Blacky.
Re: 2021 Dunn Run
Brett027 wrote: Mon Nov 29, 2021 5:58 pm I am pretty certain both circuits have to be boosted in NSW - well according to my local cert engineering guru anyway.
Depends on the engineer… nothing in NCOP from memory that requires a booster (I could be wrong) provided you meet the pedal force test.
For the meth monster, I’m going VH40 on fronts only, with engineer happy with unboosted drums rear.
For Number 1 Sons VL, I’m going unboosted disks front/rear (Willwood setup).
Re: 2021 Dunn Run
Thanks Harv. That would sure make the job easier. I think I'll fish around for another certifier.
Re: 2021 Dunn Run
Brett027 wrote: Mon Nov 29, 2021 8:51 pm Thanks Harv. That would sure make the job easier. I think I'll fish around for another certifier.
Yeah it seems to be a real crapshoot over there , at least in WA they are fairly consistent with whats required.
