Bonnet mounted windscreen washer squirter
Re: Bonnet mounted windscreen washer squirter
Maybe it was the later EJ that went to twins?
Errol62 wrote: Sun Jan 24, 2021 8:59 am FB were integral to the wiper bezels. They are much cooler of course but wouldn't look out of place on EK.
BILLY BLACKARROW
Post by BILLY BLACKARROW »
Harv wrote: Fri Jan 22, 2021 4:39 pm 8.75” from the trailing edge of the bonnet to the centre of the hole.
I vaguely remember something about you had to put a stronger washer pump on yours what did you end up using and doe's it work properly
BILLY BLACKARROW
For the FB, I've got a Trico glass bottle, vac pump, twin wiper bezel squirters and NASCO dash switch. The vac pump worked, but soon crapped out... the rubber diapgrams do not age gracefully, and are not serviceable. I gutted the vac pump, and installed a SuperCheap electric pump inside it (stealth upgrade). Hid the electrical wires in the vac lines. Worked awesome.
For the EK, I've got the single bonnet squirter, aftermarket alloy washer bottle, modified HK switch (EK knob) and SuperCheap pump. Dumbass me didn't realise that the alloy bottle had no vent. Washers worked well, but would dribble across the bonnet (engine bay heat cooked the alloy bottle, water expands and pushes out the squirter). Insulating the washer lines and putting in a check valve did nothing. Drilled a hole in the bottle lid, and problem went away.
This is what I have,
I'm sure it was bought as a Holden unit many moons ago.
Nice, looks period. I still like the FB ones though.
Looks like FB squirters in a fabricated housing ??
Pretty certain thats a Trico - will take a pic of mine for comparison - if you want to trade for a pair of Trico Squirters I have a pair of NOS ones with perfect Chrome.
EK283 wrote: Tue Jan 26, 2021 6:01 pm This is what I have,
They were in the original Trico install kit.
SunnyTim wrote: Wed Jan 27, 2021 7:33 am
FJWALLY wrote:Maybe it was the later EJ that went to twins?
EJ had squirters under the plenum cover. These units aren't Trico to my knowledge, they are US I think
Sent from my SM-N976B using Tapatalk
ImageImagethese were in the kit - fitting instructions for Fb included ImageImageImage
ImageImagein my ute
