After Market Heater
Aftr Market Heater
Very tidy bracketry Marty. Yes you will need to ensure there is no tension in the hoses with that setup or they will pull the grommet out. Might suggest if you need to adapt hoses to do it elsewhere. I had this issue running warmaride off red motor because the red runs larger diameter, but almost looks like you have to step up size to that heater.
artyfartymarty
Re: Aftr Market Heater
Post by artyfartymarty »
gpi wrote: Fri Apr 24, 2020 5:18 am its upside down isnt it?
the sticker on it says its the right way up ?
i'm not sure there is right and wrong way for these things.
i guess i could flip it to have outlets point up
FB EK Club WA
Don't follow me, I'm lost too
artyfartymarty
Harv wrote: Fri Apr 24, 2020 7:08 am That firewall grommet is the aftermarket Rares one. It is very, very thin compared to the original GMH ones. I found that the heater hoses had enough weight that they would pull the grommet out, repeatedly. Ended up running with a loose grommet for a while to let the hoses find their "settling" point, then superglued the grommet in place.
yup it is the rares grommet. original crumbled into dust once touched. i think the coat of black paint over the face was holding it together.
noted re the hoses. might have a think about making a hose support S thing attached to something solid and stable on both sides of the firewall
FB EK Club WA
Marty, Billy,
Am I correct in arsyouming the sirroco unit has just the two demister outlets, no cabin outlet?
Clay
BILLY BLACKARROW
Post by BILLY BLACKARROW »
Yes Clay only two but after rego I intend to move them so they warm the cabin ,The quarter vents are the best demister anyway :yeahhh: :yeahhh:
BILLY BLACKARROW
Thanks billy yes they are
artyfartymarty
Bracket welded together painted...
Bracket and Heater.JPG (41.82 KiB) Viewed 14195 times
Painted Heater Bracket 2.JPG (33.38 KiB) Viewed 14195 times
Painted Heater Bracket 1.JPG (37.86 KiB) Viewed 14195 times
FB EK Club WA
artyfartymarty
heater unit in place...
heater installed 2.JPG (85.99 KiB) Viewed 14194 times
Heater installed 1.JPG (51.79 KiB) Viewed 14194 times
FB EK Club WA
artyfartymarty
yes...it was originally spearmint. liking the idea of original colour more and more.
FB EK Club WA
artyfartymarty
so, after the advice on here about the hoses and grommet setup and trying to slip straight hoses onto it and checking the bends required to get to the firewall at a reasonable angle, I'm considering making use of the engine bay heater hoses in the cabin with the 90 deg bends at the heater. The edge of he heater is about 10mm from the side of the glovebox so a bit of trimming of the glove box will be happening.
FB EK Club WA
