Grey Motor Drag Car Build
BS
Re: Grey Motor Drag Car Build
Post by BS »
I've been a bit slack with updates however, I hit a bit of a milestone this past weekend with the car passing its second IHRA tech inspection.
Latest update here:
https://jalopyjournal.com/forum/threads ... d.1142966/
In summary I had the car pretty much to turn key stage minus the bottom end work and a set of headers. Monty (IHRA Inspector) was really happy with the car and gave me the go ahead to blow it apart and paint it. The painters at work are slow at the moment and Keen to paint things other than ozcam so over the last couple of days they have been flicking some jam around on it for me.
Getting closer...
Hambsters is cool 8)
I reckon even Auscam would look better than that &*#@ logo on the radiator :lol: . That thing has a serious cage in it.
BS
Post by BS »
Hahahaha to be honest this thing is probably more Toyota than anything else...... but we will keep that quiet
Yes the cage was a massive headache. It was running a 4 point cage (like all the others) but after the little girl got killed in Perth in the junior dragster all he rules changed surrounding rollcage specs and I had to cut all the rear of the cage out to make it 6pt if i was any chance to get it past IHRA tech. Serves me right for taking so long with the build as the rules were not retrospective (all in the name of safety go figure).
Anyway, its done now. The IHRA are happy with it and I've literally just taken it out of bake so now the fun of putting it all back together while getting the bottom end sorted.
BS
Post by BS »
All done. Assembly time. ImageImageImageImage
Sent from my SM-N960F using Tapatalk
That's looking great !
Massive spray booth, is it for truck / buses etc ???
BS
Post by BS »
Kind of.... we build/service armoured trucks
BS
Post by BS »
Home with minimal damage bouncing around in the back of the ute. Now to remember how it it all goes back together ImageImage
BS
Post by BS »
So far so good. Managed to get it back on all fours and keep most the paint on ImageImage
Joy
BS
Post by BS »
Updated for those following.
https://r.tapatalk.com/shareLink/topic? ... source=app
Engines built, clutch and gearbox back in. Getting closer to fire up time. Image
Looking good - look forward to the startup video :)
BS
Post by BS »
Another update in the link below for those interested
For those who can't get the link to work. It's getting closer!
Ive entered the Carralbyn 1/8 mile drags at the end of Feb so deadline is tight but achievable pending no major stuff ups between now and then.
Looking good.
I reckon turn the Strommie snorkels around though, and force feed them air.
BS
Post by BS »
Harv wrote:Looking good.
What's your reasoning Harv? I've seen lots of opinions about which way is best with mention to air pressure and other technical reasoning but no actual hard and fast data so interested in your thoughts given the work you've done with your guides.
Once I get the thing fired up, bugs sorted and a decent reliable baseline it was something I was going to play around with.
I've never tested one (say with a manometer), but I suspect that the scoops behave like most objects. As the air flows around them, it will build up a little bit of pressure on the leading edge. The "little bit of pressure" is good for increasing air flow through the carb. You won't get a massive increase (and number one carb will get more air than number two or number three because they shadow each other), but it all helps.
As the air continues to flow around the scoops, it splits into two, then joins back together behind the scoop. At the trailing edge of the scoop, there will be a slight vacuum. The vacuum again isn't huge, but it will lower airflow into the carb. In this case, number three will be most affected.
So I reckon turn the scoops so they suck from the higher pressure leading edge, instead of the lower pressure trailing edge.
If the carbs were under a closed bonnet, the effect would be negligible. Hanging out in the breeze on the Hambster though they should get decent airflow.
