Red Rattler Revamp
Re: Red Rattler Revamp
Is there a difference in size and hp needed to push the v6 or v8 vn vp t700.
What box will you be using mate.
FB-Special
Big block 161
Holley sniper EFI.
Ek auto column shift.
Lj diff and reverse lights.
WA FB~EK Car Club Member.
Big block 161
Holley sniper EFI.
V6 T700 that was very kindly donated by NoMad , who I believe is a VERY happy boy today
Good stuff mate is that a sonic injection crank trigger set up I see there? What ignition are ya gunna run on it?
Yes it is , bought a coil pack kit from Shane as well , think they are AU coilsgledge wrote: Thu Nov 01, 2018 8:17 pm Good stuff mate is that a sonic injection crank trigger set up I see there? What ignition are ya gunna run on it?
Ah i see nice one mate thank's .
FB-Special
Big block 161
Holley sniper EFI.
Big block 161
Holley sniper EFI.
Both boxes can be built to handle, the V8 one can take more though. i was told they both suck similar power but cant confirm thatmph wrote: Thu Nov 01, 2018 1:26 pm Is there a difference in size and hp needed to push the v6 or v8 vn vp t700.
Also the VN VP V6 is a Buick pattern not turbo pattern... but behind a 6 an adapter would be required regardless
and you cut an ear of the box to suit starter motor mounting
Nathan
Foundation Member
Foundation Member
Motor is all together now ready to paint , then I can throw it back in the hole so it can go to get some pipes made
Looking good mate
- WesternWagon
- State: WA
Nice work, should liven it up a bit.
What’s with the different rocker arms?
Gazza
Gazza
Member : Holden Car Club WA.
:ASRF Member
:ASRF Member
Two cylinders missing in my book but supercharged gets it over the line !!!
When we torture these engines on the race track they like to pull the caps away from the block and split the bores horizontally.
Keep the revs down and you should be right for a while anyway !!!
Gold rockers are tarnished from the exhaust heat
PS don't mention pipes for a day or two please !!!
Hi Blacky, do you have any detail on the “HR front with Cortina rack and Landcruiser brakes” adaption? Sounds interesting.
Looks like a few more gold teeth for the rat.
Will take some pics as it goes together mate, some of the lads in Vic are using this Cortina rack setup with good results , there was a guy doing the conversion in Vic but he is slow and impossible to get a hold of so I am going it alone , as for the Landcruiser brakes I have stolen that idea off Gledge , have a look at his build threadfbidek wrote: Thu Nov 15, 2018 10:38 pm Hi Blacky, do you have any detail on the “HR front with Cortina rack and Landcruiser brakes” adaption? Sounds interesting.
They are off my old speedway motor , 1.6 on the inlet , 1.5 on the zorstWesternWagon wrote: Thu Nov 15, 2018 4:28 pm Nice work, should liven it up a bit.
Gazza
