You sure its not the Crank Gear thats worn or cut wrong?
Cheers Theo Z............
Timing gear set
Re: Timing gear set
FB/EK Car Club of QLD.
- Craig Allardyce
- State: VIC
Re: Timing gear set
Crank gear is the standard one. Speco don't sell the gears as a set, just the cam gear.thropzed wrote:You sure its not the Crank Gear thats worn or cut wrong?
fb cruisin
- State: NSW
Re: Timing gear set
I had a new steel timing gear fitted to my FB, and I bought a Speco one because I thought they were a reputable brand.
Should I be concerned about the quality of mine.
Cheers Rob
Cheers Rob
______________
living the dream.
living the dream.
- Craig Allardyce
- State: VIC
Re: Timing gear set
Hi Rob,
I guess if yours has been running for a time is not noisy or causing any other probs such as vibration etc I wouldn't worry. Potentially I could have got one of a bad batch that has been sold on Ebay by some person who grabbed it out of the bin. In saying that mine was bought from the Speco distributor in Moorabbin.
- Craig Allardyce
- State: VIC
Re: Timing gear set
Yep that's it Tim, I did have issues straight up. Its the timing gear set I used in my EK ute when I recently built the engine.SunnyTim wrote:I have only used one of the Speco ones but it did more than 3,000 miles before I sold the car. If you were going to have issues you'd have them straight up I'd expect.
Sent from my SM-N910G using Tapatalk
- Craig Allardyce
- State: VIC
Re: Timing gear set
Got a set and all sorted. Thanks to Bill & Nick of the Vic club.
Re: Timing gear set
A bit late for Craig, but it looks like the Master Engineering dies for Grey timing gears are up and running again in South Nowra:
https://www.facebook.com/Master-Precisi ... 5/timeline
- Craig Allardyce
- State: VIC
Re: Timing gear set
Thanks Harv. I have spoken with him but it'll be a while before he starts production. I think most of the stuff will be the old stock bought from the old company till he gets through it and then starts back up. With great thanks Bill and Nick from the Vic club helped out with a set in the mean time.
