My second ek
toey1977
Re: My second ek
Post by toey1977 »
mmmmmmmmmmm dunno
Re: My second ek
My van is pretty good in the rear floor (same as ute). Can send some photos when I get home on the weekend. You may be best to try and find a van as donor as the rear floor is more likely to be intact. Although I hate the thought of cutting up a van or wagon for that matter.
Re: My second ek
Hey Toey doesn't even the sedan have the same floor pan except for the fuel tank hole (that might sound a bit Irish) I thought the rails etc were all the same.
When you look in the ute just behind the divider between the cabin and tray you should still see the bottom back seat ledge in the floor pressing, could be wrong been wrong many times before
Might be easier to get a sedan floor cut and just enlarge the hole for the tank or do what I'm doing with my ute and fit different tank altogether, I'm using a VP commodore tank because I'm V6ing my ute and will modify the floor to accommodate it, I did the same on my FC Sedan.
Just a thought mate
Neil H
Re: My second ek
Re: My second ek
Sedan floor is different rear of the axle. Imagefloor in the commercials is lower to accomodate the spare.
If you don't need it to be original you could fabricate the rails and use the floor and tank from something suitable. That leaves you with the question of where to store the spare, how to fit spare wheel door etc.
Either way you're up for a challenge.
toey1977
Re: My second ek
Post by toey1977 »
Thanks errol26 that helps a heap
I'm not to fussed on originality but having it look close to his it should for a rwc will help. I've got a sample now was close to what I was thinking.
mmmmmmmmmmm dunno
toey1977
Re: My second ek
Post by toey1977 »
Errol62 wrote:My van is pretty good in the rear floor (same as ute). Can send some photos when I get home on the weekend. You may be best to try and find a van as donor as the rear floor is more likely to be intact. Although I hate the thought of cutting up a van or wagon for that matter.
I'm the same as you I couldn't chop a van up either
mmmmmmmmmmm dunno
toey1977
Re: My second ek
Post by toey1977 »
FireKraka wrote:Hey Toey doesn't even the sedan have the same floor pan except for the fuel tank hole (that might sound a bit Irish) I thought the rails etc were all the same.
Just a thought mate
Neil H
Yeah the ute runs the same floor to the back seat area but from there back it is different. I've got a plan on what to do now but long weekend time is here and I ain't going into work Image
mmmmmmmmmmm dunno
Re: My second ek
Toey
Have a look at a build thread on the FE FC Forum called 365 Weeks, on the first couple of pages you can see what JB did to the floor of his ute and the fuel tank set up, this is one of the best builds for detail on the floors that I think I have seen.
Looks like you know what you are up to but it may give you some ideas.
Hope it helps.
Neil H
toey1977
Re: My second ek
Post by toey1977 »
FireKraka wrote:Toey
Hope it helps.
Neil H
Thanks mate I will have a look
mmmmmmmmmmm dunno
toey1977
Re: My second ek
Post by toey1977 »
This mornings before work tinker
mmmmmmmmmmm dunno
toey1977
Re: My second ek
Post by toey1977 »
Well after a few patches a few hours one bit of rust is nearly done
mmmmmmmmmmm dunno
toey1977
Re: My second ek
Post by toey1977 »
Which means it's now onto a rail tomorrow
mmmmmmmmmmm dunno
toey1977
Re: My second ek
Post by toey1977 »
Now to fabricate the rail
mmmmmmmmmmm dunno
FATBOY
Re: My second ek
Post by FATBOY »
i might have a rail will check this afternoon
