Neils Frankenstein Ute
Re: Neils Frankenstein Ute
Blacky wrote:I would definately trial fit before cutting that out - someone else on here not too long ago cut out an auto hump by mistake ..... :problem: :problem:
Could be worse... I've got a manual body, which someone welded an auto hump into. I then bought a CRS tunnel to replace it. Wondered why the TH350 fit with no drama without a CRS tunnel. Still didn't believe it, until Dave pointed out that the CRS tunnel was no better than what I had :oops: .
Definitely fit the driveline, check the tailshaft angles, then only cut it out if you need to.
CHOPPED
Post by CHOPPED »
hey thats looking great neil
id love to come for a drive and check it out
maybe we could do a garrage crawl
be a nice drive to serpentine
paul
HEY IT WASNT ME
CHOPPED wrote: be a nice drive to serpentine
We were nearly going to have the AGM at Serpentine pub - heard they do a nice hamburger down there , theres a Tractor museum so maybe we could do a run down there in October ???
Thanks Blacky;
It wasn't you that made the mistake was it by chance :whistlinggg:
This is a photo of the hump from the fire wall I dont like the gearbox to hang to low, like I said the loop is already really pretty chunky and I have to change the 2 outer pieces anyway as they are badly dinted up underneath; I appreciate anybodies thoughts on this.
Neil H
Hey Guys it would be great if you did a run down to Serpie the pub does have great meals at a good price and I have plenty of parking at my place (on 5 acres not far from the pub)if you guys would like to have a look I would appreciate the input; just don't hurt too much :laughinggg:
Paul you are welcome; anytime after giving me a hand with the console on the FC I owe you big time and if the club wanted to do a run and go for lunch we might have to get numbers and book because the pub gets really busy on the weekends or maybe a BBQ at my place just let me know.
Neil H
We will organise something while we are at Geraldton mate - you are going arent you ??
Sure are Blacky already booked; with my job it is hard to get away sometimes so my wife and I are really looking forward to having a bit of a relax it is a bonus that it involves cool cars.
Better let me know how to join I think I am going to have to even if it is for the T shirt :dohh:
Let me know if any of you are down my way before hand am always happy to have a beer and chat about cars.
Neil H
wot179
Post by wot179 »
Cut that mess out and go again.
Check out my old ute thread if you are unsure on where to start.
Personally I would bolt the subframe on before starting and do it all on jackstands to stop it moving about when you start cutting and welding.
Jake: SCMODS?
W.S.C.C.A.
St Marys chapter.
CHOPPED
Post by CHOPPED »
geraldton :?: whats going on up there :evil:
HEY IT WASNT ME
wot179
Post by wot179 »
My guess is piss sinking and sausage sambos.
Jake: SCMODS?
W.S.C.C.A.
St Marys chapter.
Hey WOT thanks for reminding me of your ute build I had been following it when you were doing the ute and had forgotten that you changed the hump, I went back and looked at the photos this morning.
I am going to go down that path as well, I had originally bought a V6 conversions hump to fit (the one in the photo) to my FC but ended up using the commodore hump from the donor car so that I was able to retain the standard shifter however you have to put a fair bit of extra sheet metal in to get it to match and it doesn't look that great underneath.
I think the existing hump will make the geartbox hang down to low and this will increase pinion angle I like to see the gearbox pan parallel to the ground.
I will put the sub chassis back on :dohh: as you suggested I hadn't though about it moving about thanks for the advice.
Neil H
I haven't updated my build for a while so I thought I would put up some more photos.
I think I am have been making a bit of progress or maybe going backwards not really sure.
Got the body up on the rotisserie that I borrowed and founds some dodgy floor repairs that I wasn't aware of, looked good from inside :dohh:
Also made a fuel tank support for the commodore tank will make a new floor panel to go around the opening and probably weld up the spare wheel door.
I removed the 2 cross supports that had been crushed probably from being used to jack the car up and found that the repairs had been laid over the old metal
Started on the passenger side, purchased repair panels from Taylors in Qld they were great to deal with and good panels.
I have cut this one down, I don't want to remove the subchassis inner leg mount point and will do the same on the drivers side.
Fuel tank support frame just clamped in place at the moment
Neil H
60Special
Post by 60Special »
Good to see that you've been busy Neil.
Have a couple of photos of an original hydramatic hump here Neil. ImageImageImage
As you can see the bracing is all above the hump. I think yours is a foreigner.
All the best with the build.
Clay
Thanks Clay for the photo pretty sure you are right about it being dodgy I'm going to replace it anyway it is just crap.
Hey Trev one of us has to be doing some work we can't all be away on holidays all the time :laughinggg:
regards
Neil H
