Shortening standard diff PICS ADDED
(AUST)Mod
Post by (AUST)Mod »
do i need to resize :wink:
(AUST)Mod
Post by (AUST)Mod »
thats my dad..... see the last pic, he has two right arms:)
back on topic, if the torana rear end is 3" shorter, it will fit nicely, and provide about 1/2" clearance between rim and inner wheelarch. if i run into problems even after the diff, i will put narrower tyres on :cry:
blacky or nomad want to weld up a diff for me?:) i can weld, but wouldnt have a clue where to start :wink:
I had an EH diff shortened 1 1/2 inchs either side,
and had the axles done also(obviously one would think)
Turns out, I only had to shorten the housing, and use LJ Torana axles.
By the looks of the pic with the ruler, and the text you wrote,
It sounds like your assuming a 3" short diff = 3" either side?
The LJ Diff & axles will give you 1 1/2" either side.
Love the wheels by the way :D
How much you shorten the diff, Is affected by right hight you want to some extent.
If you want it low, you'll need clearance on the inside & outside of the tyre.
A higher ride hight, will clear the rubbing easier.
Regards Jeff
(AUST)Mod
Post by (AUST)Mod »
no i understand its 1.5/ side. i think this should do, although i wouldnt want to turn any corners too fast :lol: whats a fair price for a torana diff?
Hi There Austmod,
Just reading with some interest and I can say you may have dramas with the inside as well.1/2 inch clearance is not really enough especially with a bit of weight onboard and and a fast bumpy corner cause the springs do move side to side a fair bit. The wheels I have are also 7 inch wide but I have pumped the guards and removed the lip to clear.
Your car looks pretty nice and unless you want to repaint I wouldn't suggest doing the pump thing. If you were really keen you could cut the inner chassis rail lip and extend the wheel arch inwards by 1/2 inch either side but again a lot of work! 6 inch rims on the ek and say 205 tyres are probably the biggest without bodymods. Anyway goodluck and think hard about body modification as you really cant go back once its done.
Don't know fair price on a torana diff,
but I reckon it would be easier (if you do it yourselves) or
Cheaper (If you have it done) to shorten the housing youve got and fit torana axles.
That all depends on the price of the tory diff.
you might have to buy a complete diff, to get the axles!
Then you'll have all the parts to go either way,
correct housing, mounts, axles & spare diff centre.
Also consider the hand brake set-up, not sure if tory's are similar?
Greg also makes a good point.
Like I mentioned earlier, I took 1 1/2" off, & my wheels have a 3" backspace.
13x6 with 215/60's and they fill the gaurds. Width wise anyway!
Cheers Jeff
I used to run 14 x7's with a 235/50 on the rear of my EK ute. It was lowered 2" and the guard lip had been cut back to the edge of the body(not by me, but pretty rough). These cleared OK except for high speed cornering. They rubbed on the inside.
But I do love American Racing mags, their quality is phenomonal compared to any other rim! Two of my mates run them and they are a really well built and finished rim.
(AUST)Mod
Post by (AUST)Mod »
iam on hollidays atm so i will get working on finding a diff and getting it in. hopefully will rego the car by friday:)
NoMAD
diff for sale
Post by NoMAD »
i found this add while surfin' the net...
dont know anything about it or the seller so you would have to ring them but:
TORANA LJ , diff, drum to drum, painted 2 Pac, 3:08 ratio with mini spool $300ono, S Lke. 0414-956-216
may help, may not but theres one option for you!
NoMAD
(AUST)Mod
Post by (AUST)Mod »
cheers nomad your a champion:)
gave him a ring but he said a guy ahd reserved it. he couldt get the guy so if he doesnt come through its mine:) Could you tell me what a mini spool is?
cheers Andrew :)
MINT62
Post by MINT62 »
G'day Andrew
seems to be a fair price for what you get :wink:
but a minispool is of no real use to you,unless :o
you wanna go really fast in a straight line,
with plenty of traction off the line
or do some killer 2 wheel burnouts :lol:
Ideal for the dragstrip etc :wink:
Basically a minispool locks the two back axles together
so they spin at the same speed,sorta like a L.S.D. diff
as opposed to a standard diff that spins the outside wheel
faster when going through corners
you should be able to score a LC/LJ complete diff for approx $100-$200
depending on the ratio, you'll pay more for a 3:08
as opposed to a 3:55
good luck with it :wink:
regards Stingray 8)
INVEST IN PRECIOUS METAL
(AUST)Mod
Post by (AUST)Mod »
oh yeah guys, is it possible to do burnouts in my car? is a 186 smoke capable?
MINT62
Post by MINT62 »
Burnout!
Ausmods shout :lol:
also forgot to mention added tyre wear$$$$with a minispool
with cornering etc, sometimes you can hear the rear tyres
chirp when a car with a minispool/welded diff backs out,
or turns slowly in front of you :?
not trying to put you off,just setting you strait :wink:
Stinga
(AUST)Mod wrote:oh yeah guys, is it possible to do burnouts in my car? is a 186 smoke capable?
Only you know how tough your engine is, but there's plenty of 186's that can smoke em up.
Then again why bother (there's me getting old) :roll: ,
Trev 8)
(AUST)Mod
Post by (AUST)Mod »
lol trev its a totle stocker except for extractors. i think it would blow up if i ever tried a burnout :) btw what is burnout technique? do you just hold the brakes on? hmm i knew those front discs would be good for something 8)
