Calling all you stereo heads ....
The low pass filter ensures all frequencies that are used to generate bass are only passed on and all the high ones which a sub cannot replicate are cut out. Some amps have modules some a switch from my experience or you can run them through a crossover. Clear as Mud Blacky?
muza
Re:
Post by muza »
Devilrod wrote:The low pass filter ensures all frequencies that are used to generate bass are only passed on and all the high ones which a sub cannot replicate are cut out. Some amps have modules some a switch from my experience or you can run them through a crossover. Clear as Mud Blacky?
I think we'd all just better take dr's word for it!!
Stock as a rock
Not so stock
Re: Calling all you stereo heads ....
Think I will just rip it all out and spend some more money on the engine - that makes nice music !!
ben
Post by ben »
Blacky wrote:Think I will just rip it all out and spend some more money on the engine - that makes nice music !!
:thumbsup: ......and take the pooch for a ride, if you want a woofer in the back
It's been well over fifteen years since I played around with stereo stuff! I reckon I'm way out of date... But I was fun! Had the system I built up tested at a show and measured at 124.6db. not bad for 2 100w rms amps :mrgreen:
RollinLow
Post by RollinLow »
Devilrod is on the money a low pass filter kills all high frequencies so your sub just plays bass.
Fired it up last night , seems to work but the front speakers are nowhere near as loud as the back ones - close enough :thumbsup:
Adjust the gain on the amp to match the front better.
The amp only drives the subdoofer Devilrod......
(AUST)Mod
Post by (AUST)Mod »
Probably fader in the head unit settings.
Blacky wrote:The amp only drives the subdoofer Devilrod......
Ok, so you can turn it down a bit to match the other speakers. Unless of course it's all the way down, then I'd say get another amp for the other speakers.... :
And that is usually how it always starts.....
The subdoofer is only there because there was a hole already cut in the panel behind the seat - the rear speakers are good , just the fronts are a bit quiet according to me mate who knows a bit about stereos - I couldnt give a rats to be honest , it all works thats the main thing .........................
