I need help from a grey motor guru!
Re: I need help from a grey motor guru!
The wise thing to do is to have the head professionally crack tested and inspected. At the same time, you might as well get the whole thing rebuilt with hardened valve seats, so you can run on unleaded without putting lubricant in the tank each time you fill up. Maybe even red motor or V6 valves for a bit more flow and a slight head shave for a bit more compression.
Thanks to all for the advice.
I decided to put the new head gasket on it and see what happens.
So, last night I was back under her, sump back on, then after cleaning the head up as best i could a put it back on.
TENSIONED DOWN CORRECTLY and so far the only thing in the sump is oil. Radiator is full. So thats a good sign.
I rechecked it all this morning and apart from a couple of oil drips where I pulled the tappet cover back off last night things were still looking ok.
I guess the real test will be when i try and put a fire in her belly.
If I have the same problem then out she'll come and get the full rebuild I was really hoping to put off until after Xmas this year.
you blokes really are a true wealth of information. Even when the old girls on the road I think I'll hang around here.
ingredient in beer
ingredient in beer
That's exactly when guys like you and me will need the forum the mostJohn wrote:you blokes really are a true wealth of information. Even when the old girls on the road I think I'll hang around here.![]()
Alan
Member No.1 of the FB EK Holden Car Club of WA (Woo-hoo
sweet!)
Yes it is, but a crack may only leak when the cooling system is under pressure (as you've probably guessed). So fingers crossed. If it turns out to be cracked, then the 132 head as per Tim's post is an inexpensive way out (providing of course that it isn't cracked). If it runs nicely and doesn't blow smoke, then you might get a few more miles out of her. But do you yourself a favour and replace the fibre cam timing gear with a new unit or a steel one. Trust me, it's a matter of WHEN, not IF, an old fibre gear will let go and leave you stranded.John wrote: I decided to put the new head gasket on it and see what happens.
If you need to get a reconditioned head, then it usually costs around $900 - $1000. The price this guy on eBay charges seems pretty reasonable by comparison:
http://www.ebay.com.au/itm/HOLDEN-138-G ... 415fa1ead2
One last thing, converting to electronic ignition works wonders on an old grey. The Pertronix 1864A kit is available on eBay:
http://www.ebay.com.au/itm/Pertronix-Ig ... 2eb82e5ed8
I have it in writing from Pertronix USA that their kit is compatible with copper or steel cored ignition leads, if you intend to run these.
The eBay seller "GMHNASCO" has his kit here: http://www.ebay.com.au/itm/Holden-48-FX ... 23178a361d
Thanks guys. It will be a Sunday driver and I want it as standard as possible. My daughter has her leavers dinner in December so I need it ready by then. I'm happy to rebuild the donk AFTER the event but I need every cent in the mean time to spend elsewhere on it.
I hope she starts ok. If she blows a little smoke it will be ok for the one day then I'll pull her down.
http://www.fbekholden.com/forum/viewtop ... 6&start=60
The pics wii show you where it's at and how much I have left to do
ingredient in beer
ingredient in beer
No offence taken Tim, nor was any disrespect intended towards your post. I was working from the assumption that an inspection of the head for corrosion had been done and the results negative.
My fibre timing gear most certainly did not last 70-80K miles. I know the inconvenience of breaking down in the middle of the night due to a fibre timing gear failure. Yes, I replaced it myself in my EK when I was an impoverished student, only using an engine reconditioner to remove the fibre gear from the camshaft and press on a new steel one. I just made sure the lifters were matched to the correct slots in the block and to their pushrods (pushing them through an old egg carton worked a treat there). I thought because my EK had been sitting for some time before I bought it and not used, the fibre gear had become brittle and this caused the failure. The Dave Beers Theory is that it is due to the stress the fuel pump places on the gear...
I recommended an electronic ignition kit simply because several club and forum members have used them and swear by the improvement they make (e.g., "Sputzwagon"). Moreover, they can be installed without professional assistance. Yes, there is one in my grey. Of course, a grey will run on points just fine, like mine did for several years.
No, I was not suggesting John spend $2K. A reco head, Pertronix ignition kit and fibre timing gear all sourced from eBay is $595 + $130 + $170 + $61.95 total postage, which is $956.95. Overall, a relatively inexpensive freshen up for a grey which gives some peace of mind.
John has expended quite a deal of effort in the body and paintwork of his EK project and I thought he may wish the engine to be of comparable standard. In any case, my thoughts are purely his for the taking - he can heed them or he can ignore them.
choppedfan
Andrew,
Would have to agree 100% regarding the electronic ignition conversion for any grey stock or modified
the only question I had after converting mine was why did I wait so long before I did it
Andrew,
Well today she fired
once I got fuel into the pump (after putting the air hose in the tank ) and putting a carby kit through the stromberg.
She sounded solid
Front seal looks buggered but that can be fixed and apart from that it seems fine.
I'm a happy taswegian
Thanks again guys for your help and advice. All very much appreciated and all taken on board
She sounded solid
ingredient in beer
ingredient in beer
Thanks John (and Mick). Let us know how you go with it.
Ok, she's a bit rattly top end but there doesn't seem to be a lot of oil getting up there either. Pulled the tapper cover off and ran her for a minute or two and the only place oil was coming out of was where the pipe from the oil pump bolts on to the tappets. What do I need to check here? Front seal is stuffed but that's an easy fix. Just not sure about the lack of oil on the tappets.
ingredient in beer
ingredient in beer
Have you adjusted the tappets?
The oil pump could be gone, as they often are on worn greys. A NSW club member recently rebuilt his using red motor pump gears, which was a cheap fix. Sam Princi might have the details on this as it was in a recent newsletter.
Thanks again guys
i'll do the tappets tonight. Front seal is shot. oil running out so ill do that too. Only other issue is a nasty leak at the rear. Now im not sure if its the rear main or the tappet cover gasket. The tappet cover MAY be a bit warped so Ill take it off and put on the alloy one i have here just to determine whether that's the issue.
It may also be the sump gasket i suppose. I did take the sump off witht he donk still in the car and put on a new gasket. Maybe not quite sealing right?
If it is the rear main I think I'll pull the motor out, hone,new rings and bearings and drop it back in. It certianly seems a solid old donk so maybe a good idea?
ingredient in beer
ingredient in beer
