SPATS
Re: SPATS
............... or fit one of these -
That way you can throttle steer the car and you wont need to use as much steering lock. :twisted:
akamanis
Re: SPATS
Post by akamanis »
Problem almost solved - I've fitted 9 inch wheels at the front so that I can now corner without hitting the spats. However the front bumper scrapes the road on a semi regular basis. Any ideas?
jack_fc
Re: SPATS
Post by jack_fc »
Fit drop spindles... upside down
Or if that's too hard, raise bumper bar...
Re: SPATS
Don't drive it semi regularly ????????????
the rocket
Re: SPATS
Post by the rocket »
i like the engine upgrade idea.
GusnElla
Re: SPATS
Post by GusnElla »
I'd re-tighten the nut behind the wheel,,, sounds like it come loose alittle too
akamanis
Re: SPATS
Post by akamanis »
I have tried to re-tighten the nut behind the wheel but the thread is burred and not sure now if it's worth all the effort of spats at the front........
Re: SPATS
akamanis wrote:I have tried to re-tighten the nut behind the wheel but the thread is burred and not sure now if it's worth all the effort of spats at the front........
It must be too old hey Geoff :lol:
GusnElla
Re: SPATS
Post by GusnElla »
Just remember.... Cross threading is cheaper than loctite....
fingers
Re: SPATS
Post by fingers »
GusnElla wrote:I'd re-tighten the nut behind the wheel,,, sounds like it come loose alittle too
To get the correct tension without a tension wrench ... :) :) ...Tighten it till it strips then back it off 1/2 a turn ......... that should fix the nut behind the wheel .... :lol: :lol: :lol: ..fingers
Re: SPATS
Post by Mick Jagger »
or you could try hingeing them from the top,greasing the outer edge of the tyres is a must
just be carefull on roundabouts as you will have to allow a little room ...
kmawic
choppedfan
Re: SPATS
Post by choppedfan »
Nash had this sorted years ago and did it with style. :thumbsup: :thumbsup: :thumbsup:
Mick 8)
akamanis
Re: SPATS
Post by akamanis »
That's it - I'm gunna trade in for a Nash!
