Shed find ute
WesternWagon
Re: Shed find ute
Post by WesternWagon »
Front end all cleaned, painted and reassembled, needs more lowering as still too high. Just need to do the rack arms one I get new ball joints.
Small block in and has plenty of clearance on the fire wall Image
Member : Holden Car Club WA.
:ASRF Member
WesternWagon
Re: Shed find ute
FireKraka wrote:Hi Gaz
Coming along nice mate you are getting a lot done at the moment.
You may have to go 15's mate that tie rod is real close even with the 15's on my FC and the 16's on EK the ute they are close.
All sorted mate got 3/8 clearance now Image
:ASRF Member
Re: Shed find ute
Great progress Gazza
thebrotherj
Re: Shed find ute
Post by thebrotherj »
Loving it Gaz. Are they flames stamped into the sump? Haha wow
Also are you gonna leave the paint as is? (please do!)
Cheers, Joe
WesternWagon
Re: Shed find ute
thebrotherj wrote:Loving it Gaz. Are they flames stamped into the sump? Haha wow
Cheers, Joe
Cheers Joe
Just a wash and a clear coat
:ASRF Member
thebrotherj
Re: Shed find ute
Cheers, Joe
Cheers Joe
Awesome. I can’t wait to see this thing done Image
WesternWagon
Shed find ute
Stance needs some serious adjustments
:ASRF Member
Re: Shed find ute
250kg of lazy yank iron in the hole up front will help a bit
Re: Shed find ute
Errol62 wrote: Thu May 24, 2018 1:21 pm 250kg of lazy yank iron in the hole up front will help a bit
I dunno... add a Moon tank, a straight axle and some fenderwell headers and that stance would make a good start to a gasser :mrgreen: .
Harv (appreciator of gassers).
Re: Shed find ute
Hey Gaz,
Still got plenty of stuff missing so it will come down a bit more.
Going well and looking the goods although.
Re: Shed find ute
looking way cool - Pedders do a shorter spring if you want to drop down a bit or you can chop them but I dont like chopping them as they tend to never sit right even if ground flat - better with proper flattened and closed ends.
Re: Shed find ute
Just heat up the spring with the gas axe til it drops. You know the drill.
WesternWagon
Re: Shed find ute
Thanks gents
I actually have a set of lowered springs in the shed. Plan is to get the ute running, take it for a drive and see how it settles.
Rear springs have been reset 2 1/2 inches lower already :shock:
More updates soon
Gazza
:ASRF Member
WesternWagon
Re: Shed find ute
Sue’s Coupe converted to 12 volts new fizzy, carb & headers finally got some time on the Ute
Cut up the steel for the chassis today lots to do before Mudgee
Now to weld it all in
:ASRF Member
Re: Shed find ute
did you have those plates laser cut Gaz or are they bought ones ????
