My Chopped wagon
Re: My Chopped wagon
Devilrod wrote:Looking good Trev, can I suggest ditching the overrides to see how it looks?
Yes they do dictate how far back the bumper goes.
CHOPPED wrote:im not a fan of the stands trev :roll:
Geez, they are NASCO Paul!
Trev,
If you ditch the overiders I will buy them off you :ebiggrin: :ebiggrin:
EK283 wrote:Trev,
I'll keep you in mind Greg.
fb delivery
Post by fb delivery »
SunnyTim wrote:it's funny I can remember this wagon sitting in a paddock west of Toowoomba some time back, not far from where I picked those bits up for you Trev................looking a lot better now
Yep, same paddock that had the white EK wagon with the Flash-line trim
{ i know as i tried to buy them, day late as aways }
Maybe those parts belong back on the wagon? Destiny I'd say.
Looking good Trev
What primer are you using ?
2k from Spray Chief.
what's the windscreen trev
Rusty EK
Post by Rusty EK »
Was thinking the same thing mick
That screen is one I chopped, I was a couple of inches off finishing and it cracked.
I'll use it as a template to get another one done.
How did you chop it Trev ???? I need to do one for the Morry .....
It was one of Mez's, it was too big by about 1/2 inch so I used a flapper sanding disc and ground it down.
If it's a full size screen I will cut it first then finish with the flapper.
Blacky wrote:How did you chop it Trev ???? I need to do one for the Morry .....
is the morry split screen or one piece, i have an unbelievable story i know a guy that cut some front screens for a '51 chev old second hand glass but laminated with a 1 mill blade on a 4" grinder :shock: :shock: if you have some laminated glass may be worth a try
