Moderators: reidy , Blacky
Posts: 2682 Joined: Thu Mar 16, 2006 9:51 pm
Post
by EK283 » Sun Sep 24, 2023 7:27 am
Errol62 wrote: Sat Sep 23, 2023 9:47 am
Going to be awesome Greg. Heard nothing but good things. Biggest issue I’ve heard is sorting out in-tank pump, which you’ve done. Nice welding by the way!
Hi Clay,
I can't take the credit for the welding as the tank was made by a fabricator here in Sydney. Top bloke did exactly what i asked and the welds are superb i agree !
Funny, I've lost a bit of zest lately and find it hard to go to the shed, heat wave last week and now cold again !
Post
by EK283 » Fri Oct 06, 2023 7:06 am
Wow,
I dont seem to have the time of late but there is some progress.
Made a new filler neck, its in your face a bit but I'll eventually box it in with an area either for some tools to sit or I may relocate the battery just behind it. Really no issue as the car wont see any big boot loads, not while i have it anyway !
Going to move the exhaust inbound and along the tank as well, spring hits them on big bumps, very annoying.
Raptor coated just to blend it in a little, subtle changes you see !!
Posts: 11602 Joined: Sat Dec 06, 2014 2:44 pm
Post
by Errol62 » Fri Oct 06, 2023 8:28 am
Good progress Greg. I was thinking about using the Raptor coating for the underside of my van.
EK DAZ
Posts: 439 Joined: Tue Nov 07, 2006 7:21 pm
Post
by EK DAZ » Fri Oct 06, 2023 3:23 pm
Yeah, That Raptor is good stuff and easy to apply.
EK DAZ
Posts: 14212 Joined: Tue Jul 20, 2004 8:58 am
Post
by Blacky » Sat Oct 07, 2023 10:07 am
I used Wurth stuff under the rattler , looks pretty similar to that
Post
by EK283 » Sat Oct 07, 2023 6:48 pm
The Raptor is 2 part and you can get it tintable, that’s what I did,
Had some left over paint called clinker grey but it looks black.
It’s pretty simple to use, goes off to touch in an hour.
Tip, it needs two coats so mix only enough before you recoat, otherwise half a tin in the bin then start with a new one !!!!!
EK283 on Sun Oct 08, 2023 7:49 am, edited 1 time in total.
Post
by Errol62 » Sat Oct 07, 2023 7:32 pm
Thanks Greg. 2k= tough. I'm thinking about 2k urethane on the van, probably in a solid colour. Bit of a way off yet, heh, heh...
melly
Posts: 137 Joined: Mon Jan 10, 2022 11:35 pm
Post
by melly » Sun Oct 08, 2023 12:46 am
Nice work Greg, tidy as always...
cheers, melly
Post
by EK283 » Mon Oct 09, 2023 6:39 pm
Bloody hell, i want to drive this thing !!
Tank in and the drivers side exhaust done, much better this way heaps of clearance and the springs can move freely without the clanging !!
I have to change a couple of fuel line fittings then wire the computer, dizzy and ignition up, all plug in but I want it neat so more time.
I'm gonna drive it a bit after these mods, no more for a while.
Post
by Errol62 » Mon Oct 09, 2023 7:09 pm
And you're going to relocate the passenger side pipe.....
Good work. Beats cutting rear quarters off an FB van.
Posts: 2785 Joined: Fri Jan 24, 2014 11:12 am
Post
by FireKraka » Tue Oct 10, 2023 10:58 am
Hi Greg are you going to have to wrap the pipe beside the fuel tank? how much heat do you get there?
Post
by EK283 » Tue Oct 10, 2023 7:05 pm
Hi Neil,
No im not a fan of heat wrap, it attracts moisture and rusts your pipes quicker than you can imagine,
There is more than an inch between them, I will measure temps when i get it going,
Absolute worst case a heat shield but i doubt the temp at the tail pipes will be an issue.
Post
by EK283 » Mon Oct 16, 2023 11:39 am
Finished the tank,
Now for the fun part more wiring, i'll update that story in a day or two.
Next !!!
Post
by Errol62 » Mon Oct 16, 2023 12:46 pm
Top job Greg! I love the pipes exiting straight and inboard like that. Still room for the towbar mate??
Bet the right foot is getting itchy now...
Post
by Blacky » Mon Oct 16, 2023 6:09 pm
Looks neat mate
I love wiring - not ..........
