NoMAD's Kustom FB Sedan
ALRIGHT ALRIGHT ALRIGHT MUSH!
yeah no worries Mephious, as soon as i've set the rear seatbelts up which i still havent been able to order, fix the bog/rust in the bottom of the quarters, sorted the battery, fuel flap, false floor, finish off other minor rust in the rear, i'll get the diff back in with the brakes fully set up...then i should be ready to take a side shot!
if only it was that easy....i'm trying!
NoMAD
NoMAD
Man....the last thing i need is even more ideas, i cant figure out whether to do half the ones i already hace or not....
I will definetly check it out however, picking it up on the way home to check out someones Yellow EK (*cough i mean FB)....cheers for the heads up Andrew,
on a side note i get my belts tonight so this should be fun!
NoMAD
NoMAD
Right as most of you would have seen the weather in Perth for the cruise the boys were organising, i decided to spend more time in the shed....
Fuel Tank Frame was screwed in, only to captive nuts to go however we need to re-drill some holes in the tank frame...
The Frame is pretty much donw just a little bit more to grind....
The Rear Lip is all welded up and finished...
The Fuel Hole is Filled....
And started work on the custom retractable seatbelts, to hide underneath the parcel shelf...
NoMAD
NoMAD
- State: WA
Nomad, your work so far on the build is inspirational.
It makes me want to take my FB off the road and do it all over again.
I was thinking of just a colour change back to original but looking at the pics of yours and other builds on the forum, the painted guages, long throw shifters and flash motors, i really really want to hot rod my FB.
FB EK Club WA
Don't follow me, I'm lost too
Cheers mate, nice to hear that once in a while, keeps me motivated during those periods of tendious work, which dont actually look like your getting results till there all done....artyfartymarty wrote:Nomad, your work so far on the build is inspirational.
If you are going to go the whole hog make sure you have a good plan of exactly what you want, cause i'm sure it will then change....
cheers
NoMAD
- State: WA
