My 1961 EK Mild Kustom Buildup.
Smooth customs
Nick
Copper or Bronze would look fine
Think about a white or silver roof, or even in the flash down the side
If you went to the Brisbane Hot Rod show, the Bronze Hudson I built was on display. This was one of the nicer Bronze orange colours we could find. And it needs body mouldings to break it up and give it that little more life
Dont go for white anywhere in your interior if it is to be an everyday drive car, been there many years ago. Looks fantastic, but no matter how careful you are it seems to get dirty.
Hey Nick, Get in touch with the rexona distributors and tell them your thoughts and they might chuck in some dollars to have a promo style car!!! based on the deoderant can use grey/silver interior with the grey/silver flash to break up all that bronze.
Just my 2 cents
Cheers Theo Z...............
Just my 2 cents
FB/EK Car Club of QLD.
Theo,
Interesting idea.. i wouldn't run the name rexona on my car though
I duno about the silver though.. as i duno what trim i'm gona be runnin just yet and i don't know if i even want it two toned.. i don't think i do.. still decidin..
I think the copper with a white interior would look unreal though..
Nick.
Another update..
First up is the very near completed sill..
Ass bit.. still have to do a little panel to make that body line "flow".
Inside the rear gaurd.. Looks shit in the pic but looks pretty wicked in person.
Front. The Subframe will be all smoothed out when i do the rust repairs on it. Will look like it never rusted at all when i'm done with it.
Also incase your all wondering.. that cut is because we accidently welded the subframe to the body. Oops.. So we just cut that and when the subframe comes off i'll trim that top plate off and reweld it to the body. Also gona end up welding a peice of angle to the body as a mounting point so instead of a bolt going against 2mm sheet its gona be going against 5mm angle.
Front Gaurd repair.. Rust cut out..
Makin the first parts of the patch.
About to be tacked in..
Second half..
Filled..
Same gaurd.. lower front.
Lower rear..
Driver door ready for filler.
Rear drivers side door..
Car from the front so far..
And the rear..
Our work area.. took this at night so you can't see everything but anyway..
Second half..
Filled..
Lower rear..
And the rear..
Nick.
Smooth customs
Nick
You are doing a great job fabricating the pieces needed and getting all the rust repaired.
But the shot of the filler being applied to the headlight area of the front guard is not the way to do it.
Where ever you need to apply filler, the complete area and say 50mm around the outside of the application zone must be sanded. All primer and contamination from welding must be removed.
Otherwise you risk all these repairs delaminating, as the surface underneath will not bond properly with the filler.
This may happen in days weeks or possibly months, and it can lead to totally stripping the car back and starting over again. This is devistating after all the work that has been put into a job and money on materials including paint.
I have seen this happen several times over the years.
DeadSled wrote:Hey,
It hassnt been bogged over shitty burnt primer.
I read his reply as a tip and not to knock your work, it maybe a good time to inform your dad what he needs to do, to prevent all the hard work you guys are doing from failing in the future.
Regards John
- Sputzwagon
Deadsled, John's right 100%!
Paul was giving you handy tips for a long lasting repair that you won't have to re-repair again only months down the line. (believe me I know 'cause I DID have bog over a not properly prepared area & had to do it again
These blokes here are NOT knocking your work, the're helping with years of experience only.
Scotty.
P.S. you're doing a better job than I could ever hope to do!
Scotty.
Woofto Car Club Member No 2
Fellas i know you all mean well..
I'll get another pic of the front gaurd today and you can tell me then if it still needs to be fixed or not. It still needs a bit more sanding anyway.. its all been sanded down to just the tiny like 10cm wide area it needed to be on so the rest is infact bare metal now.
I'll show yas later
I'll show yas later
Nick.
