Dave’s EK supercharged v6
Re: Dave’s EK supercharged v6
And in the a pillar bottoms 3/8”
Hosed everything out I recon there was about 1 kg of dirt but no sockets haha
Next piece ready to weld in
- 4B6CFAEF-069C-4529-ADBA-01A44914D3F2.jpeg (2.88 MiB) Viewed 1684 times
looks a little thin around the sway bar mount,...
Same as before. Plate just sitting in at the moment so it’s a bit low once I lift it and weld it, it will be good
Other corner now fully welded just need to grind back and clean up
Chassis strengthening plates tacked on ready to seam weld
- 839914C6-630D-4853-B32F-8571FA22A285.jpeg (2.76 MiB) Viewed 1636 times
- 5D63A879-19A1-4E96-8167-B27EAD5A2064.jpeg (2.74 MiB) Viewed 1636 times
- 3F128236-19C0-4BC7-9398-C10A9A1317FF.jpeg (3.08 MiB) Viewed 1636 times
Good stuff Dave. Can you tell me what gauge/thickness the reinforcing plates are?
Not sure mate but I will measure for you this arvo
Sorry just checked. They are 3mmErrol62 wrote: Thu Feb 24, 2022 10:35 pm Good stuff Dave. Can you tell me what gauge/thickness the reinforcing plates are?
Thanks Dave I guessed they’d be 3mm. Thinking about when I do my subframe after the main shell.
I originally had them welded to another front end but cut them off and put on the new one. Much better doing it this way as I originally welded them laying under the car…….never again
