Shed find ute
WesternWagon
Shed find ute
Post by WesternWagon »
Now back to the ute
Painting all the small bit after a swim in the Citric
Then made up some dust covers so I can blast the nine inch, I have a few diffs to do
Trial fit of the diff, then remove tomorrow and blast and paint and get it rolling
Will be good to get it off the hoist
Poor old wagon looking neglected
All packed away until morning
Member : Holden Car Club WA.
:ASRF Member
Re: Shed find ute
Its not dark yet , why are you knocking off ya skirt ???????? :lol:
WesternWagon
Shed find ute
Bit more on the ute today until the welder carked it, so bolted the diff in so I can trial fit the rims in the morning
Got the drivers side sub frame in and some rust repairs on the A pillar
:ASRF Member
WesternWagon
Re: Shed find ute
With the welder out I robbed the wagon to progress the ute front clip on, pick up steel for chassis in the morning and hopefully fit The engine Image so I can sort the radiator
4 inch backspace and its still bloody close, but I want 14’s
Undercarriage getting there
:ASRF Member
WesternWagon
Shed find ute
Trial fit the 7 inch rims on the nine inch, about an inch clearance on the outside and an inch & 3/4 on the inside
Looking at 225’s so may have to reset the rims
:ASRF Member
59wagon
Re: Shed find ute
Post by 59wagon »
Looking good, Gaz. Wedding shots real nice, too.
John
Re: Shed find ute
Hi Gaz
Coming along nice mate you are getting a lot done at the moment.
You may have to go 15's mate that tie rod is real close even with the 15's on my FC and the 16's on EK the ute they are close.
Re: Shed find ute
That sounds about right for 205s. Unless you have really stiff sway bars you’ll get rubbing o the inside with body roll.
WesternWagon
Re: Shed find ute
Errol62 wrote:That sounds about right for 205s. Unless you have really stiff sway bars you’ll get rubbing o the inside with body roll.
215’s on the Sedan are fine with no rubbing I’ll squeeze em in
:ASRF Member
WesternWagon
Shed find ute
Quiet day today so I dropped the rims of at the powder Coates and the headers are getting ceramic coated
Sue’s A Coupe ones came up a treat, Local Powder Coaters did a great job
:ASRF Member
WesternWagon
Re: Shed find ute
Got the ute rims back from the powder coasters today done in Black Ace, looks like ceramic
Awesome job
Got the headers off the coupe ceramic coated also
:ASRF Member
WesternWagon
Shed find ute
Got the back wheels on even with a 2 1/2 inch reset on the springs still looks like a 4x4 ha ha might make some lowering blocks so I can see how much I have to lower it Image
Get the chassis kit plates back from the plasma cutters next week then fit it all so I can clear the hoist for the Nats
Hope no one needs it
:ASRF Member
WesternWagon
Shed find ute
Front end has been sitting sooo long it needs a tidy up before I fit the engine Image
Some flat clear coat and the rotors should come up a treat
:ASRF Member
59wagon
Re: Shed find ute
Post by 59wagon »
Nice work, Gaz. Looks like you’ve got a busy period coming up.
John
WesternWagon
Re: Shed find ute
Rotors came up a treatImage
:ASRF Member
