Rebuilding of Old Timer (EK wagon)
weldin gPOR
Hi Stewart,
was wonderin were you were with it.
just a question .. did that POR stuff take weldin?
I know its good stuff for just bare steel but havnt seen what it does if welded.
I'd be puttin some more on to any of it whch got burned off.
Dee
Dee
- Contact:
Many thanks Gary, Dave, Dee, John and Frank. It's been a while since the last update. Things ARE happening but life is fairly hectic and time isn't something I have had a lot of lately. Also Loui has picked up a few other jobs...isn't that right Dave68... ...how's the ute going?
Dee - POR handled welding OK. Yes more POR will go over the welds.
Will post up some more progress pics soon...
Stewart
Stewart
- Contact:
Thanks Marty. Dave - no need at all to apologise. I'm looking forward to seeing your ute
- Contact:
OK time for an update…seeing the last one was 30 March… I guess that's what happens when you only spend a couple of hours every weeks or so (if that)... slow n steady....
Goes without saying Loui is doing a top notch job in the welding department and I'm getting pretty handy with the grinder...
Remaining floor plan section welded in
That outer sill has to come off…
Hmmm a few previous repair jobs there...
Outer sill off
To find…
All cleaned up with some more die grinding to do...
Another piece to the jigsaw...
Two coats of POR and some rattle can for good luck...
Rear dogleg...yep it's a mess...
A pillar outer skin in place
Outer skin welded in...time to get the grinder out...
next chapter will be get the doors back on so the outer sill can be lined up for welding in .
Outer sill off
To find…
- Contact:
You're on the money Finny...we started with the hardest sections first and once the pasenger outer sill is in I might even admit that we have just about broken the back of it...all downhill from here...just both rear quarters, fire wall, subframe, gutters both sides, front guards, petrol tank well, zillions of other holes...Hmm on second thoughts...maybe not... travel into the future...freudian slip that one I think...
Too right Ben...trouble is I'm thinking that after all this work I'm going to be very paranoid when its on the road. Thanks Trev and John.
Here's the latest installment:
Looks can be deceiving as I have found many times...donor section reveals swiss cheese after blasting
trial fit...
final cuts and fireworks
welded in. The thing I have learnt with the rebuild is even though you can cut the identical piece out of another EK...it will be different...in this case there was a 5 mil width difference in the dogleg section
Outers sill tacked in. The passenger side sill proved a lot more difficult than the drivers side...maybe because there had been previous sill repairs? Notice too the gap at the bottom of the rear door. The door gaps are spot on at the top and the sides but the bottom gap proved terrible. The actual bottom edge of the door drops to the rear quarter...any suggestions?
trial fit...
