What is there a particular brand of 2in extractors that will fit a 161 red motor in an EK?
Anybody have any for sale? or should I just get some made up?
Extractors
Pacemaker, is one brand.
Just be careful you don't put on extractors and exhaust that is too big for the engine, you need what is called "back pressure".
For example, I had a 2.25" exhaust fitted to a standard 173 and drove it like that for about 3 years and it went fine, then I changed the twin carbs for a single carb and 1.7/8 inch exhaust and the power increase was unbelievable
Don't get sucked in J, Trev
Yep Trevs right, the base on the grey carby is smaller and the mount holes are closer together than on a red motor.
Also the base should have cast into it "BXUV-1" for a grey and "BXUV-2" for a red in most circumstances from memory.
Red carbys will be either 1 3/32 (138 red and 149 red ), 1 5/32 ,1 7/32 cast into the carby body.
basic.green
Hi J do not buy advance extractors (they sell them in sa) they are no good they go down to close to gearbox and you cant get to the bolts
i had to buy another set. not happy
the maker said we have sold thousands of them and nobody has complained
i dont no if they sell them in other states but try be for you buy.
building the dream Rick
