Whats this part called?
MBH222
Post by MBH222 »
A pictures worth a 1000 words and I have tried to outline the part Im referring to.
Its a rubber cup that goes over the handbrake cable and sits on the end of the handbrake shaft.
This rubber has perrished and split so now the handbrake cable keeps popping out. Only lasts a few pulls then popps out again - tried a few time already
Im off to the auto shop soon but going in with a part name would be much easier to explain. Would this be a hard part to source and if so can anyone from the Sydney/Sth Highlands area recommend a shop where these are stocked?
Thanks.
FB MAD
Post by FB MAD »
According to my GMH master parts cattledog Holden gave it the very inventive name of "Grommet":- (handbrake cable through dash) and has a Holden part number of 7409488 and fits FE/FC/FB/EK.
Can't tell you anymore than that sorry.
Post by mrs ratbox »
that doesn't hold the hadbrake cable in all the ones i've come across they're held in with a bit of tie wire, if you look on the shaft where the ball sits in you'll see a groove the wire sits in, pain in the arse to just did one
MBH222
Post by MBH222 »
Thanks FB Mad for the part number :D
ratbox - ill give your remedy a go. thanks for the help.
FB MAD
Post by FB MAD »
There's one on ebay right now.
Item number 380103530393.
