Which one do i get the one on the ute hits the out rigger is there any tips
regards fatboy
Front Swaybar with hr front end
- Sammy
- Contact:
from what i can recall there are two different ones, one has a section that goes forward (towards the radiator) around the harmonic balancer and then theres one that goes down in the same area ... i thnk the down one will hit your outrigger but the forward one wont.
Regards,
Sammy.
http://www.oldholdens.com
Sammy.
I've got a big K Mac swaybar on mine that was on the car when I bought it.
It's near enough to an 1 inch or so thick and points to the front of car just above the outrigger and near the harmonic balancer.
When I lowered the front ( about 3 inch ) I found it was knocking against the outrigger at times.
To remedy the problem, I cut, shortened and reweld the "swaybar to lower control arm links" by about 2 inches or thereabouts.
That gave the sway bar "pointed bit" a different angle near the outrigger and stopped it from hitting/rubbing on the outrigger.
Hope that info helps,
