NoMAD's Kustom FB Sedan
i'de take a pic of my work boots but i'm not at home if any body has seen me i prolly had them on (dougle bung black rubber thongs) so man up guys these are the same work boots i used to wear when i worked in a foundry yes pouring moulten metal and such, back in the good old days before them numbskulls from workcover started sticking there dikhead beaks in
hey nomad did you do any thing to the wheel studs machine them down or somthing,,, as i was trying to get rid of the lock nuts on my ute with my old dragway nuts of my other car and they are differant size ie 1/2 inch to 5/8s
nah mate i haven't done anything with them...karsten wrote:hey nomad did you do any thing to the wheel studs machine them down or somthing,,, as i was trying to get rid of the lock nuts on my ute with my old dragway nuts of my other car and they are differant size ie 1/2 inch to 5/8s
also front seatbelts are in minus the buckles and the centre belt - maybe i might get them done this weekend....but have alot of things on!
NoMAD
- Aussie Bob
Yeah Finny,
little progress, Rust has been cut out of the FrontGuard where the battery was, and stated replacing with the section i got from Blacky (Cheers - even though it was many moons ago now)
Front Seat has been stripped down and all the frame work getting a good clean up before it gets put away for a while before i get to the trimming stage....
started coming up with ideas for rear lighting in the pillars, and working on the sump to suit the HR Front with the Rack & pinion...
soory guys no real photo's to show yet as soon as stuff's finished i'll put up the before and after pics... am also picking up a ute (HQ - aquamarine mettallic, 253, 4 speed on gas, GTS everything and dragways) next week for a daily driver so that will be getting a couple of weeks of attention to tidy it up nice...
cheers for the interest!
NoMAD
NoMAD
....that's right bells are going off... had an hour or 2 to myself this arvo and did a little work...
after having to go get a new sander, discs etc... cause the old one shat itself so did the usual 5 mins (1.5hr) trip to bunnings... then lunch... and realised i had about 15 mins left but streched that out and got to work on the brake booster...
enjoy... grinding/ sanding not compeleted yet and i want to make us some sapces as i want to booster just off the firewall...
NoMAD
NoMAD
- Contact:
Hi what sort of tank did you use??? Cheers markNoMAD wrote:
Also a shot from underneath, the Tank needs a new clean and fresh coat of underbody in some areas, but this is just to so off the Diff Assembly, which i'm also pleased with, would be great if it never came out again....
NoMAD
FB/EKForum member 123
Woofto Car Club Member No4
