any tips on gettin the rear side windows out would be handy as i plan on gettin them out tommoro
cheers matty
rear side windows on wagon
always a good day for cars
hi mate
just get yourself a hook and pick set, about 20 bucks at most auto shops then its just a matter of patience. using the L shaped pick start at the top either corner from inside the car then just work the rubber over the metal lip that holds it in place, WD40 or CRC help but be sure to clean the rubber after your done.
Use the palm of your hand to push it out but gradually otherwise youll put your hand straight through it. Work around the sides next and bobs your uncle. Just make sure youve got a helper on the outside of the car to catch it
