i think theres 4 half inch heads nead socket with exstention long one,,,,,,,, in the inside of front pillar ,,theres 2 on the bottem rear of guard to body ,,the support bracket in the wheel arch has two,,, and underneath between stone tray and guard,,, once all are out pull gaurd away from body at the bottom rear of gaurd in front of door and pull it out and upwards which helps it go forward , they can be flexed alot,,, make sure the bumper and support rod are undone bumper gone,,, disconnect head light wires first and poke the grommet and wires through the inner gaurd ,,, and just work her loose
